Bet you were eggstatic to have to do that![]()
I changed it in the staff carpark at work so not been able to drive it yet. I did start the engine and checked there were no errors and it would give boost using the Torque app on my phone.Have you noticed any difference?
Shampoo'd the rear carpets and mats after carrying two dozen eggs on the back seat and having to break hard for a bus that hesitated at a roundabout
Changed the windscreen/rear screen screenwash pump by removing the drivers side fog and changing the pumps over and cost £41.72 total so nice cheap fix for a VW pump to go in. Only took about 10 mins max to do.![]()
Could it be condensation caused by the cold weather?Changed the front PCV valve only to find a bit of mayo in the old pcv and in the oil cap FFS it never ends![]()
This the cam follower or something else? Is it bad?Managed to break it![]()
Yeah the cam follower change ended with the thread on the brass fuel pump pipe cross threadingThis the cam follower or something else? Is it bad?
That a new bolt/rethread or new hpfp?Yeah the cam follower change ended with the thread on the brass fuel pump pipe cross threading![]()
I can see you can unscrew it from the fuel pump so hoping it's just a new pipe needed. I had just finished fitting all the service parts to go on as well and can't start the car to test it runs ok as it spews fuel when the ignition goes to stage two.That a new bolt/rethread or new hpfp?
A new pipe is much better than a new pump, annoying when the simple jobs turn into a pain in the butt, hope you get it foxed ASAP.I can see you can unscrew it from the fuel pump so hoping it's just a new pipe needed. I had just finished fitting all the service parts to go on as well and can't start the car to test it runs ok as it spews fuel when the ignition goes to stage two.
