What did you and your MK2 do today?
JohnnyMackers
31
17
Not today but Sunday gave a good wash, clay and polish, used autogylm shampoo, super resin polish.. didn't take any pictures though apart from it raining yesterday and noticed the roof.
Quite a few swirl marks in paint which I'll sort out.
stephen
82
10
got some h7 led bulbs of ebay just to try them, brand nighteye or something
the passenger side went in fine and lined up great, drivers side, wont line up for some reason and i get the normal error message on the dash
but they seem nice and bright
need to get another look at the holder see what is happening
there is meant to be adjustment holes, but there is only one hole, so cant move it much
Legojon
I only wanted a remap
5,311
2,741
Just to check. You put them in with the tag at the top I think it goes? Maybe taking a picture from the front would help so we can see it. Maybe it's catching on those little diffuser things.
Reactions: stephen
stephen
82
10
Il get a look on Saturday in daylight. I must had the second one in wrong. The first went in great no problems
Need to read the manual too see if the lights are meant to be vertical or horizontal
Order a canbus corrector thing too see if that gets rid of my warning
stephen
82
10
got the bulbs in today
the problem with the one bulbs that wouldn't go to the place meant too was the wee tags on the bulb itself
so a bit of electrical tape and that sorted it
not sure if i like them mind, the light if very close to the car, does it go far im used to philips racing vision and they seem to through the light more up the road
and with the need of the ebay 2X H7 LED Load Resistors 50W 6 Ohm Stop Car Light Flicker Cancel Error Message and thats just bulks everything up, cant put the rear cap on so its a mess with cable ties
but they are in and working, no error and not blinding anyone
ZiggyEP3
406
72
UK
Changed my recirc valve to be surprised to find my car had an 8 year old Revision D. Put a revision G on instead as its the better of the two types.
Im sure its not meant to but the old recirc came apart when lifting it out.
Reactions: Brimfull
Brimfull
1,385
418
Wrexham
Have you noticed any difference?
Legojon
5,311
2,741
Shampoo'd the rear carpets and mats after carrying two dozen eggs on the back seat and having to break hard for a bus that hesitated at a roundabout
I thought it was some kind of new cleaning idea I'd not heard of. Just smash 6 eggs on each mat... oooooooo.
Yeah, mine fell to pieces as well. Which was ace as I almost lost it down the pipe when it did!
Reactions: Brimfull
ZiggyEP3
406
72
UK
Changed the windscreen/rear screen screenwash pump by removing the drivers side fog and changing the pumps over and cost £41.72 total so nice cheap fix for a VW pump to go in. Only took about 10 mins max to do. :smoke:
Rusty2k
710
134
£42?? That's crazy money for a part like that. Respected brands like Febi Bilstein start at around £13.
Glad you've got it fixed and working though.
ZiggyEP3
406
72
UK
Changed the front PCV valve only to find a bit of mayo in the old pcv and in the oil cap FFS it never ends :cry:
