Could it be condensation caused by the cold weather?Changed the front PCV valve only to find a bit of mayo in the old pcv and in the oil cap FFS it never ends
This the cam follower or something else? Is it bad?Managed to break it
Yeah the cam follower change ended with the thread on the brass fuel pump pipe cross threadingThis the cam follower or something else? Is it bad?
That a new bolt/rethread or new hpfp?Yeah the cam follower change ended with the thread on the brass fuel pump pipe cross threading
I can see you can unscrew it from the fuel pump so hoping it's just a new pipe needed. I had just finished fitting all the service parts to go on as well and can't start the car to test it runs ok as it spews fuel when the ignition goes to stage two.That a new bolt/rethread or new hpfp?
A new pipe is much better than a new pump, annoying when the simple jobs turn into a pain in the butt, hope you get it foxed ASAP.I can see you can unscrew it from the fuel pump so hoping it's just a new pipe needed. I had just finished fitting all the service parts to go on as well and can't start the car to test it runs ok as it spews fuel when the ignition goes to stage two.
What is the Instagram name Jim?I'm looking for some awesome car pictures from you lovely people to put on the forum Instagram, if you think your car has what it takes please have a look at this thread for what to do.
https://forums.seatcupra.net/index.php?threads/pictures-needed-for-instagram.448851/
Haha I hope it lives up to expectationsGot it
I want mine back I'm bored of the Merc already just had it remapped today still boringHaha I hope it lives up to expectations
Sell it lol get a mk2 simplesI want mine back I'm bored of the Merc already just had it remapped today still boring
