DaNnY_LaD's IHI'd Cupra ( End Of a Eara 08/11/2009)
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
When the water lines are on, we can take it for a drive Danny and i'll log it so we know what it reads when it stalls
Can you explain a little Bill what the different options on Lemminwinks are for fuel, i know theres a few but specifically what they do i don't know. What option would you adjust if say you wanted to add more fuel in when its coming down the revs to a stop?
The ones i can remember off the top of my head are:
Increase in load
Decrease in load
Start up fuel tweak
Warm up fuel tweak
Primary fuel tweak
Secondary fuel tweak
I know there all at 100% but it still allows adjustment
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
you have named the main ones yes..
see what its doing first.
these adjustments are no substitute for getting it mapped..
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
Mine had the odd cut out when cold until it was mapped. Go careful Danny. You wouldnt want to do any serious damage or stress things too much by driving it unmapped after doing so much.
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Thanks everyone...
Mucho appreacited once again....
Fitted the Coolant Lines tonight and then Pulled my back..How i done it il never now.So im gonna see how tommorrow goes at work then go doctors i think..
There all Bolted up and Fine but i left a washer off the Coolant Line on the block were the Spacer is so its slowly dripping out so depending on how i feel tommorrow il give it anothe bash.
Also going to order so Thermal sleeving for the Surrounding Pipes/wires as IMO its gonna be very hot down there..Plus its very close to the rear engine mount...
Once We've done it all and got all the air out if it overheats while driving Normal and not when Idling its gotta defo be the water pump...which is only £30 Posted from ECP but would mean me fitting the cambelt(new) twice then as i wanted todo all this one my Engine Gets a rebuild in a months time...
I could Possible fit the Rods my self with new Bearings ect and keep the Excesting Rings as i don't have the Tools to de-glaze the bores for new rings...I got Drews Dad off here to Replace new seals in my Cylinder head for a Decent enough price and a Full Clean up too...Just a matter of taking the head off and taking it too him then he can strip it.As i don't want to disturb the Cam chain ect...
Anyway will look in to it.....
760
best way to know the water pump is working is when the engine is cold to take off the coolant cap then the top hose that goes in the the coolant bottle hold it were the cap goes and rev the car at around 3500 rpm if coolant comes out of the hose like a mofo the water pump is working as it should be if there is no coolant or its very poor the water pump is gone
takes 2 mins to test does not have to be hot
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
Finally got Danny's car running without over heating tonight its still stalling when coming down the revs, tried to log it when it does it on block 001 but it didn't come out to good, you can see it does do some big jumps from positive to negative though. I still think it may be the fueling as it hasn't been mapped or anything yet
Code:
	Group A:	'001
		RPM	Temperature	Lambda	Bin. Bits
	TIME
MARKER	STAMP	 /min	°C	%
	0	840	83	-0.8	10111111
	0.37	840	83	-1.6	10111111
	0.77	840	83	-2.3	10111111
	1.26	840	83	0	10111111
	1.66	840	83	0.8	10111111
	2.06	880	83	1.6	10101011
	2.46	2400	83	0	10110101
	2.97	3160	83	0	10110001
	3.37	2720	83	0	10110001
	3.77	2200	83	0	10110101
	4.27	1680	1.695	231 001 200	-271.5
	21.66	840	84	3.1	10111111
	22.16	840	84	0.8	10111111
	22.56	840	84	0	10111111
	22.96	840	84	-0.8	10111111
	23.36	840	84	-1.6	10111111
	23.85	840	84	-3.1	10101011
	24.25	1920	84	0	10100111
	24.65	3240	84	0.8	10100001
	25.15	4000	84	-89.2	2.71
	34.36	840	84	1.6	10111111
	34.76	840	84	0.8	10111111
	35.16	840	84	0	10111111
	35.56	840	84	-1.6	10111111
	36.05	840	84	0	10111111
	36.45	840	84	0.8	10111111
	36.85	840	84	1.6	10111111
	37.25	840	84	2.3	10111111
	37.65	840	84	0	10111111
	38.05	840	84	-0.8	10111111
	38.45	800	84	-1.6	10111111
	38.85	840	84	-2.3	10111111
	39.25	840	84	-0.8	10111111
	39.75	840	84	0	10111111
	40.15	840	84	0.8	10111111
	40.64	840	84	2.3	10111111
	41.04	840	84	3.1	10111111
	41.44	840	84	3.9	10111111
	41.84	840	84	1.6	10111111
	42.35	840	84	0	10111111
	42.75	840	84	-0.8	10111111
	43.15	840	84	-1.6	10111111
	43.55	1240	84	0	10100011
	43.95	2280	84	0	10100001
	44.35	4200	84	3.1	10100001
	44.75	4920	84	0	10110001
	45.14	4280	84	0	10110001
	45.54	3680	84	0	10110001
	45.94	3160	84	0	10110101
	46.34	2640	84	0	10110101
	46.74	2120	84	0	10110101
	47.14	1640	84	0	10110111
	47.54	1280	84	0	10110111
	47.94	840	84	0	10110111
	48.45	840	84	-1.6	10111111
	48.85	1000	84	-2.3	10111111
	49.25	960	84	-3.9	10111111
	49.84	920	84	-4.7	11111111
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Big thanks to chris & lauren for helping us out...
I love it to bits just sooo nice to drive it again and the way its feels..
The only consern ive got is down there its Uber hot i mean really hot so my fans are coming on all the time plus i forgot how stiff it was compared to my transit van lol...
Alex:
Come on msn mate when you get a minute need a chat.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
I cannot work out why you're driving it about on a narrowband controlled ECU without being mapped
you must either be
a) Stupid
b) Ignorant
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
even though you're most likely doing & will continue to do damage to it?
madness!
I should have added 'c) rich' to the list
jamiebennett81
Danny why would you do all this work and then be using the car as a daily driver to be pootling around town?:blink:
the mind just boggles......
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
ill advised, but you dont listen to advise much Danny
be carefull else it will end in tears fella
For one im not ignoring advise...
so i can't even drive normal with stage 2 just the normal pottering around..I thought atleast i could do that to get normal miles ón it and sort any teething problems out...
Before i even consider getting it mapped.
Jamie..It isnt a daily driver more of a toy as i have a work van for my job...
