DaNnY_LaD's IHI'd Cupra ( End Of a Eara 08/11/2009)
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
Code:
	Group A:	'001				Group B:	'032
		RPM	Temperature	Lambda	Bin. Bits		Lambda	Lambda
	TIME					TIME
MARKER	STAMP	 /min	°C	%		STAMP	%	%
	5.13	920	72	-6.3	10111110	5.63	0	0
	6.12	920	72	-8.6	10111110	6.52	0	0
	7.04	920	72	-5.5	10111110	7.44	0	0
	7.84	920	72	-6.3	10111110	8.24	0	0
	8.63	920	72	-7.8	10111110	9.03	0	0
	9.53	920	72	-6.3	10111110	10.03	0	0
	10.52	920	72	-3.9	10111110	10.92	0	0
	11.43	960	72	-7.8	10111110	11.83	0	0
	12.23	920	72	-5.5	10111110	12.63	0	0
	13.32	920	72	93	103.95	22.52	0	0
	23.03	920	73	-7	10111110	23.43	0	0
	23.83	920	73	-7	10111110	24.23	0	0
	24.63	920	73	-5.5	10111110	25.13	0	0
	25.62	920	73	-7.8	10111110	26.12	0	0
	26.63	920	73	-6.3	10111110	27.01	0	0
	27.41	960	73	-4.7	10111110	27.81	0	0
	28.21	960	73	-2.3	10111110	28.61	0	0
	29.01	920	73	-6.3	10111110	29.41	0	0
	29.81	920	73	-7.8	10111110	30.21	0	0
	30.61	960	74	-5.5	10111110	31.01	0	0
	31.41	920	73	-3.1	10111110	31.81	0	0
	32.21	920	74	-3.9	10111110	32.61	0	0
	33.01	920	74	-6.3	10111110	33.41	0	0
	33.91	920	74	-4.7	 ?	43.11	0	0
	43.51	960	75	0	10111110	44.01	0	0
	44.52	960	75	3.9	10111110	44.92	0	0
	45.32	920	75	3.9	10111110	45.72	0	0
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
Block 032 is on that log Bill and it didn' do anything, as you can see it just shows zero. Don't know if it will have changed now hes driven it?
We can always re-do this one if need be
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Im wondering would i benefit from a 20vt Large port Head? As ive been offered on with 40k miles with 20v n/a cams inside for £200 posted..
It would make it easy for me todo this so i can get the head built 1st...
Worth a punt or not?
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Thanks Bill
Filled her up tonight and took her for a spin with the misses...Went for a drive for around 30miles which was nice been sooo long since i drove it prober at all..
Im going to check my water pump this weekend as the gauge went past 90degree but only to the next notch.. i have a feeling i hadn't got all the air out of the system when i fitted the thermostat would i be right?The fans are coming on tho....
Got some little vids of it 2night excuse me lol i was like a little kid..
Its just felt prober nippy love down...Just goes to show what drivin a transit can do to you lol
http://www.youtube.com/watch?v=9VN58b3GUXU
In this one is for the exhaust note but once its warmed up and you rev it you can see it cutting out...this happens coming up to junction when i rev it too much? Boost leak ???
http://www.youtube.com/watch?v=kv6yHfDYocY
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
righto im leaking from the coolant banjo holes on the coolant line for the IHI...They seem to be m14 as the Holes on the turbo & Banjo bolts im using are a M12...So its leaking abit of water...
Now this is what i got with the IHI wen i bought it...Could i cut the Coolant line and fit this on to it and jubliee clip it on it?
The piece im on about which m12 coolant Setup..
And this is the coolant line ive got on at the moment...Could i just cut the bolt banjo off and slip the hose over the other part and jubliee clip it..
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
The lines I got were considered not upto par when my IHI was being fitted so they had some new ones made for similar problems you are experiencing. This was for both oil and water.
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Yup...Be doning some measuring and this IHI water Banjo i have here would work a treat...
Would fit inside my Coolant line too and a jublie clip around it..
What you think?worthy of a try..
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
After Mucho Pissing about we've desided to make are own Coolant lines...to say the least im pissed of that i paid for these lines expecting them to ****ing fit....which they clearly don't
we've salvaged the Barbed Jointer & Coolant Banjo fitting on the block side seems all we have todo is get some 10mm I.D Braided Line and jubliee clip it on as each fitting has a barbed edge..Only a Small set back but something i should'nt have to fix...
Anyway the bits were using which fit PERFECT...
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
Thanks Chris for all your help and genius ideas! :rolleyes: Yet another late night on your car Daniel.....you can repay with jaffa cakes, brews and chocolate biscuits :D
