DaNnY_LaD's IHI'd Cupra ( End Of a Eara 08/11/2009)
HTC
Sep 2, 2004
421
Since you have bought the IHI flanged mani I won't mention Garretts. For the record ceedubya made 375bhp with a TD05 18G. This is the turbo I'll be fitting to mine. What I found very impressive was it hits full boost (30psi spike on his) at 3500rpm. ie very good street turbo in my opinion with a nice wide power band. I've had my TD05 apart and measured the exhaust A/R at 0.50. His one doesn't surge as far as I know. You will need bigger injectors. I'm fitting siemens 630cc items to mine as I have the AGU head with longer injectors. Not sure what type you'll need.
You will need an inline uprated fuel pump. Bosch 044 or walbro 255. Fit an LCR intank pump as well to be sure.
TD05 housing water cooling inlet and outlet thread is 14mm if that helps. Stock oil outlet from the k03 fits the TD with just a slight elongation of the holes. Stock k03 oil inlet pipe fits too with the correct banjo bolt. You'll need to make a new air inlet pipe for the compressor, but that's just a case of getting the right silicone bends. Compressor inlet on the 18g is 60mm. I don't know what it is on the 16g. My 18g is also from scooby clinic.
jamiebennett81
Hows about a F**king Holiday sound... Hers and her Mums idea...[:@]
they dont understand do they....my missus wants a holiday and a flat...I wanted a Big turbo...but that didn't go down very well :lol:
jamiebennett81
I know U'd think the Too Would Mix together
got a Abs Light tonight and scanned it and got this Code
00285 - ABS Wheel Speed Sensor Front Right (G45)
how much are new ones?
I had this done on mine recently....top of my head about £80 I think, but dont quote me on that
this only happened on mine though due to the wheel bearing was screwed and had pushed it out....are you sure yours is ok Danny?
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
Theres that plate behind the sensor mate that i mentioned, mine threw up a similar code cause i bent the plate when a wheel bolt was too long, just hammered the plate a bit so the sensor didn't touch it no more and it was fixed! Ghetto...but it worked
If your struggling can always have a look at weekend with you or summat, got a couple of bits to do on my car anyways :D
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Yeah Sure...It might even be a wiring going to it,I havent had time to look at it yet..
Hows the camera shooting coming on,You found out how to use it? could got to a Empty Multi-story carpark at night and get some decent photos..
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Check the wiring mate before you get a new sensor, i got the same code and it turned out to be that the wiring had rubbed through.
New sensor is about £26 from ECP IIRC.
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Cheers mate...Il have a look 2morro..
Today I pulled My finger out and got on with the cleaning for when i start to wax-oil underneath ect...
I also Highten the rear of the car by 40mm And Leveled out the front by around 5mm as it was'nt handling as good with it so far down at the back.
Got a few bits that I wanna Customize my self along with smoothing in my Pods and Leathering Up my Interior plastics.
Im Picking up my Compressor on wednesday with Paint gun which i got for a bargain price of a mate,So i can then do my Wheels Properly with 2K paint Instead of the rattle cans ect...
Just saving at the moment for a Full Re-spray In Yellow With the front Bumper Repaired and smoothed which i hope should be after the holiday in around a Months time.Even tho the body work has done around 143k miles it isnt ''Perfect'' for me...
I Rang my local Exhaust place up this Morning and its going in Next saturday for a 6x5 Deep oval Backbox as i aint Keen on my Milltek Style BackBox..
Anyway Some Cleaning Pictures in Progress:
That was the arch's ect
All i have todo Now Is actually Polish & Wax it
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
***Update***
Just to Mention that the Gt2x hybrid is Running just Outstanding had a little Play with a Audi Rs4 i think it was and was Dead level with it...The Audi Sounded Just so fecking Awesome...
It hitting 1.55bar and holding it to 6320rpm With 0 Cf's....
Gonna Look in to a RR maybe in 2 weeks wanna see what its putting out....The Boom i get when it comes on boost it Awesome :D
jamiebennett81
***Update***
oh come on Danny...an Audi RS4...maybe mid range for a short while, but top end no, and off the lights again no
