DaNnY_LaD's IHI'd Cupra ( End Of a Eara 08/11/2009)
ryan_s3
1,270
no good mate 280-300bhp max and inlet cannot be removed without replacing the compressor housing.
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
Td05 16G is exactly the same flange pattern as a VF34. Should fit the mani fine. Check the mani welds from the inside. Tig-art told Bill they do not do full penetration welds which is not the best.
ryan_s3
1,270
You might aswell buy a new big 16g or 18g for the price of a hybrid or go for ihi option
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Well it been kept and the turbo setup is getting ditch and the internal are getting uprated..
So the turbo setup is a TD05H-16G with Underslung Turbular manifold...
IVe alread Put sourced the Manifold and ive sourced a Td05 Turbo for £100 Posted Which i will make it in to a 16 Or 18g ...
This Month Is engine Mounts,LCR fuel Pump And EBC
As ive already got all the Gaskets and il be using a BAM crank and Pistons with 20mm Pin Rods And supertech valves...
My Bhp goal is 350bhp & 350ft-lb which is acheivable with a 16G...
Then il Get some cash together for a Spec or sach Stage 3 clutch...
jamiebennett81
fecking nutter, game on though mate:)
look fwd to seeing it all together
ian_cupra
LMAO ok then mate, good luck with that one, should be awesome when your done
