Just had a call from garage i took it to they havent a clue wahts up with it all they can tell me is its loosing fuel pressure when it comes on boost rather than increasing it so not sure what that relats to?
Have you changed the fpr? I haven't read back through all the post so apologies if youve ruled it out. I'd also be checking the fuel pump (check voltage under boost), filters and everything else associated with it.
djscorch Quote:
It might we worth checking your injectors and seals Chris, I was losing boost through mine because the fuel rail was lose. Only did it under heavy boost, the injector was being pushed out by the pressure. Stank of fuel after i'd give it some.
