Ronin225's Candy rimmed Black LCR - Project 500-4WD, Cage installed and bigger turbo
IH786
396
Birmingham
Also noticed over the last few weeks its seems a little reluctant to start and after scanning the ABS module it came back with the fault 00688, supply voltage too low or short to earth, if i try to reset it clears but the handbrake light flashes and beeps then reflags the fault
I think im going to have to check all the connection and lugs from when the battery relocation was done, a quick search seems to point to the ground on the starter
Unless anyone else has any input on it
I have the same issue too. Let me know how you get on with sorting it :D
Ronin225
4,652
22
Worcester
My lid turned up last night too
Following the Ronin theme
Its technically a motorbike helmet (doubt theres a difference between car and bike) and heavily padded so nice snug fit, 4 star safety rating and all delivered for £50
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
Good price that, looks sweet mate. Yeah doubt there is much difference between a bike and car helmet. They both serve the same thing so all good
Ronin225
4,652
22
Worcester
looks great with the red wheels.....bet it handles like a dream
Cheers, this crap weather coupled with nearly worn out tyres means its not too good at the moment though
Would be a worthwhile investment for you too if you plan on more track time
Where did you get it from mucka?
http://www.helmetsuperstore.co.uk/
Nice helmet mate....... ;)
I need to invest in one myself.
Get it done, worth the money when you think how much it costs to hire one
Seal_LCR
2,601
Redditch
Theres fire protection in a autosport helmet and believe it or not they offer a better safety rating then motorcycle helmets but not alot
Ronin225
4,652
22
Worcester
I dont think it has a sun visor, just a plain one but i bet you could buy different screens to fit
However ive not really had a problem with sun in my eyes on the days ive done
Ronin225
4,652
22
Worcester
Interesting
I dont think the fire safety is too important being as im not caged so an exit should be quick and failing the the marshalls are normally quite good
Ape
-----Hairy Hoonigan-----
I've taken my visor off on occasion, I normally take it off for use in the car, and keep it on for karting. Wait until you come over a crest or through a bend and that big fiery ball is in your eyes, it's not nice :funk:
Ronin225
4,652
22
Worcester
Only does it sometimes, say 1 start out of 20.
Yes battery has been relocated. Will try and clean and earths this weekend and report back :D
Let me know if it works as mine is doing it nearly everytime now and ive been under the bonnet to check all the connectors are firmly seated
It originally started after hitting a few huge bumps the brake wear sensor light came on but would reset with ignition cycle and thought it was dodgy link in the arch.
I dont have the ABS light on but unsure if the system is working or not, may find out if it snows tomorrow though
Sound familiar?
Ronin225
4,652
22
Worcester
Managed to get some time on my ramps to finish fitting some bits
034 solid subframe bushing and mine really didnt want to come out as everybody elses have but got there in the end
Then i thought i'd fit my VF engineering mount
Got this far and then realised i only have part of the mount, i dont have the bar that joins the two mounting holes on the gearbox and the bolts to suit
So after a temper moment i've put my OE one back in, FFS!
I then fitted some new boost hoses ready for mapping
New one connecting charge pipe to the start of my welded I/C pipework
Then the throttle body to the outlet side of the I/C pipework, you can also make out the new MAP sensor position
So all fitted
Just need to get my new tyres fitted and inside of my wheels sanded flat now
Ronin225
4,652
22
Worcester
Just how the pic looks, i should really cut the join on the TB at angle to suit properly but i wanted to go sledging so its fine for now
