ND-Photo.nl 's - Seat Leon ST Cupra 280
Cubbington
172
132
UK
I love that you can only see a slight hint of the front upper strut brace
AP1GczPfar9yRvCkKHC2mXbjs915m3iztQX0GXbtY4gE9KDEl2pJKfKVyII5no9cAmtGPExrS3_FKWo2GN39jnMh9MHBtwNgkaGpRWrQ7DktRzzS7DlffpP75QK968tPTFakIcQdh2Tzg9NNnBGPjpGbdEp37A=w1920-h1080-s-no-gm
AP1GczMPsrOiyqzF3cCbHtCR0p1HtdnkkDoDVPOmSwi9RxsUGvpGCyIsg9F53OWGac2NgIKYsV_YNY0NWLqIq1iGKLiwQI5BJazVXiRshwPy9qdzCp_ftmMajc4B40vTf3hMERCInMYqeRi6QP0IFo-RwrXQKA=w1920-h1080-s-no-gm
Do you feel any difference with it fitted? Would be almost invisible on my red wagon 😎
nd-photo.nl
4,193
346
The Netherlands
youtube.com
nd-photo.nl
4,193
346
The Netherlands
youtube.com
Found a bigger filter with a velocity stack, which should work better than the provided filter
AP1GczPzx3GhdDcMoHyrKtkmYD4osqaTCK4RZW1Mb32pEomoY1PKC-NEXdzEFTbFR2cbMsODw8S3DeWushfTK2ylWj6mHza0KMj0xlZXZ-xelWJ1YveS3kip7PRqACJJVqAnazlXD_eQoQe5vnfK4grW1VTstA=w1920-h1080-s-no-gm
AP1GczMYOy40s77v2tmZCYtAOjI3UKt5DxWZf1EIPqKQ-z0x_iq8H41ptRkR5nk5tXjhM0et5pWqN-QK5Qs034Zd8N1j3z-av4C_fGO3eN9NSv7J2OTmZCjx-APwNZ0yZ4TkWdaj7Ty-QQK5NGMvDnhF2o00IA=w1920-h1080-s-no-gm
First fit, already looks way more impressive (y)
AP1GczOsUc7JpUeTm0byUfmT_9Y-MpNw0BlCHvRvZdWoX1bHii8gyXStnsKOkBtcFJIdN-L-J01ydFQt-PvKuFqskwsfJlpJmoXxz4oYnAdnm3fLeKVWxSuBm8WvM9IdOL8Krf5ikLu4Bh8TQW9Oyp6MJ_HY_g=w1920-h1080-s-no-gm
Problem, the hood would not close haha
AP1GczMmfWbnpLAN60znzNYkIyYU7fmy5D7FAfaPuHkRherplCKFe8wUKdRAi9mN175EltUPufMhKwrEX5KEuDew-V7EtDXt7F2pIg9wepnLHRf-QRgfK4cYo63AcALubWECsoE4cR2b3qgpM2LSUikKB378cw=w1920-h1080-s-no-gm
Unfortunately, I had to remove the heat shield for the bigger filter to fit. I don't worry too much about a missing heatshield and the possibility of higher IATs
AP1GczMThxmJcUtSfhVvPLBRnajV45YY7jcIWVFrOh8_d1YYR9rfoIQwO-36ut9eoUBBfk0fzJb9tXGbSXXUPhwa9WMPjhJQ6yDw9jLElhDdr9LHWXOrGIynUEJUVr6mO8dn4rVXovQkb7M6xrBBFZ16dZLIng=w1920-h1080-s-no-gm
AP1GczPWe2P7T_sGDwQAy4FTTRW2qnmnvwZioQqIBf05DIKE1FXQepGmowB9HTPZcm90z17sj9MENK2mwaWxXPEv9hzgQLkIEhShkC8ijlz2nTQi92CN3NsA4CMSL6hGqOtthiAyQltvf4NTzQAItaF4awD8Yg=w1920-h1080-s-no-gm
Problem solved :worship:
AP1GczNX7qLxTDU2sMy4CfLfXuJmflTuX983VNV-0i1ClzKadYzZzrFQOp3YKqQej_d9GcdSoJBHZXv7gGz7u6NYSNc33xy7PJo1D5Q4GPalXlGyQrbUnEhRv-W-TWEO_kwrTCUqAhywv2BqIY4AARzbf7PjWw=w1920-h1080-s-no-gm
Reactions: Mo_86
Drax
7
Legends say u don't need cold air for a turbocharged engine because of the intercooler that cools the air but idk. I would want better sound over lil bit of power too if I had petrol engine :D
That engine bay pretty clean! :>
nd-photo.nl
4,193
346
The Netherlands
youtube.com
@Drax it is! But that will probably change over the next months with warmer weather and it becomes more dusty over here. Right next to my driveway is a small patch of land where a horse normally resides. In the summer I can wash my car every day if I want to with all the dust.
Picture for clarification. The Fiat 100HP is from a buddy of mine, proper machine made for fast cornering. Also I like his exhaust note
Click: https://www.youtube.com/shorts/zezQqu4QL7Q
AP1GczNMLVB51G8fHHvkkmvNK50zpb19uwovoych9e7TazeXa9XMoU4nITKf4UN1vHXnio2zRrWf4ylhKbY7V4lr7oAuWP92E2cdSTijY5FF2UVFS9DXQQr-cXFxnXozjvoROnOdVMR5CeOuKVPO07VT7w2MFw=w1920-h1080-s-no-gm
nd-photo.nl
4,193
346
The Netherlands
youtube.com
Some preventative maintenance, replaced the camshaft position sensor. Straight swap, done in a matter of minutes
Bought one from Hella
AP1GczMNU0-9ezB8UzbsFAPwTohprJiyQ8e2kNQJybJC7WaTpz8Y5ZsgrToKdY1u3lIKolj6x3dRuUilQWpThcJ5MrLGH-m6iprHm2hSwwST_zheNZUIjSq3FYtLsrki2a_l6aouNQNdMGKlV2V7mX3lg0c8cg=w1920-h1080-s-no-gm
AP1GczO1swncI3YnzuFoSSTkEqYEeOSh_ZVMR_rCVrPe2qpiWuTw0edJDA3RcPizS1i6QYlo__psImCcjENQIEut-PjK8vs66CljqWx3ysYdSIcX-ZXwMnIUV3MtTeQnROEAziuYGIoDSyDrsTWhp5wKiRhAGQ=w1920-h1080-s-no-gm
Old one out, the silverish stuff is LiquiMoly MoS2. On pictures it looks silver, but in reality is a dark grey matter
AP1GczP703q-AY2yTkBuUnPyIyeGiKaYh9SJoMXV6BHyiokecTH4T3qmWHUQn9klzyzKcdVlrY9Z1SraQNjwgwScs_PoqARLmihmkjkdwFB0lYKxPijnpmWaNREMuiLqsQShrNO_mfqfERnlbxoVH_8Lwp5z7w=w1920-h1080-s-no-gm
All in place
AP1GczNTcdiryZcC5T2TeSUp8L0V6_3giN9-gzxUMscHNJfV-soc4_2ah99pO4xh3Pjv_-yrTOGeqfCkri8sk_cQ6PPOOZawCumOKTudMiro12W-QpSFhVyDDL-vFLEdN2Ua64Pv4fJpyZxeNBOOja4_hylxpA=w1920-h1080-s-no-gm
AP1GczNfpEtR426dTHPgMf_LUOOoq868whjiVPRwGk0G1eX_LeeR4eQ0BSxQV0irz1TOsIWuTODGci4CM7xZCwGmOBZQ8ghebd_mBLM52oyxGh-LRIvEBA5s4I3hCt5j97JGiWKtaKp8BkfWTvbynX5z3891PQ=w1920-h1080-s-no-gm
Reactions: Drax and jksoarez10
nd-photo.nl
4,193
346
The Netherlands
youtube.com
I like to try things, so when I can find a bigger filter, I will buy it and test it. Bonus points when the filter has a funky color :happy:
Left: provided filter with intake
Mid: Velocity stack filter with aluminium top hat
Right: Big purple filter with open top
AP1GczPgiOgtDUWxNxdNhZjlhCW91fbtRWq6f0GCfffgObT0KCivE8zepEwrfDIarRwCjjfXMfl0zGm4yPTuT3DrZRZP088Ji2nVE_dpusU0A1DdWJ5D0LPuXvHSbYfIkP4Qwv5H4jaJvufFo_vTrVivKmx40A=w1560-h878-s-no-gm
AP1GczNuxCmf6vtj-QYmQMzPyL86izaNOerjaVUScSKBWDrXpzVjGSDabwjfe24YvelK8YzmQu3BnNWYPLuT-z7ksZ5VEv-nSoicI146b4f6ayFJ8Dp6AnjPPFRJ7N8ynOmHlermajrgrQUpcVuybQzzbnfBGg=w1560-h878-s-no-gm
Insides compared:
Provided filter
AP1GczPo3AA0_Hvssn1srpxW7CzgTo1iVRMJskiOKY7OfilyYY7LAB1Rdt_BsSeICIUr2Lr4I42X_9aOrSyBK9lEZBhJ9rSkWU3QXi_N2QIzA2WcWQn0a3meIuIGaKcLkjpX_OgwH_xhc39jvPfxLur4BVWIlQ=w1560-h878-s-no-gm
Velocity stack filter:
AP1GczOr8_m43DkEF5PgmKVMs80lvs6Ks7E16Uwyk3-Q2bjygpsOawPMCym8i8LIs-3lUVIGJO9T9beFP6u8uJF6nl43knj3Vk3wOuswR8bHulgeTFZvGV-ZcMp9caYOkC7eWY9z5Rwjb6ylPvP9LQy5ftc-zQ=w1560-h878-s-no-gm
Purple filter:
AP1GczO216XD31U3nEfP6u1naxxhQbW_vT_2i9GC83pUgRjnxdQ3QITEHTRIGcqJWcjrbpaAs5-SUwU7fwYUihdMRLEI5vpoWxKxvrYx3DHB4AsPCkOHvWHOlqo6jd5dMWiO5S3XNTFN5sWWsp4eUYx0pU3o-w=w1560-h878-s-no-gm
nd-photo.nl
4,193
346
The Netherlands
youtube.com
And a little preventative maintenance, replaced the serpentine belt and the tensioner. Seems there was an oil leak a little while ago, so happy that I replaced them.
Went with a Continental belt and INA tensioner, even though INA also supplies a belt with the kit
AP1GczNPUcwuMyVHqkxbM-1Ec_GbNWdbsnRkdVOSeSrbI_rbdaSOwUMU71k8Xo00Tbr8yLIzcsPWsNZTsJH4NibBrE8Q_R7-a19VWTAseYobuTA9Mqu8VL2cxsKudIM5FeZrunGT9XKn9rvP1Q0iy7aX6FzYXQ=w1920-h1080-s-no-gm
Its not too horrible to replace, you need to remove the top part of the washer bottle (it slides out to the top)
AP1GczO72K9EWRoslNV4kljwPn5JZVvEVxu2hDxYWSXWQa5faXQIqHBKexHU5AG4CZlYiKRwSHODleKJt0osWZ2v11ejCzX5YUo4B1JXyipscRbRFeZ3kzBSf-10I-QTFHeQzDu9VRnlDzjMrlxmeJ7Vf_XzXg=w1920-h1080-s-no-gm
Stained by oil...
AP1GczMpzg9opxij1I92UVKR7xA-dt76pSfPxsJYg6nEmb6Ul-NKKQbcVoztXEse_srxISge_U6HTLskD3XOgwz18-21_o9D5HoyQaqVDoD8djq6WBGI86zhWA6qUR-EAvDUvPDPUf_g8nuekS0oL6uAmBPtFA=w1920-h1080-s-no-gm
Rearside comparison
AP1GczN4eHfDuniDugi4KQQLgk-f8LpmDZDJBIGjKP_z79IfbWNfTMDuhu6tSf0QEcYJ-0vZ7ScwRzdgqqPCNf1K7FXi9Zqw3gUmK8Jez9FlPNrBlDkKDmyitwXlGERHXy5q1Z7gDrPB12UBhQ1rfDIzZw1TOA=w1920-h1080-s-no-gm
Added a date for documentation, which should be 2025 :ROFLMAO::banghead2🙈
AP1GczM5WrdSmg2FsDk7kf2MSPva2hG3lvMlE31uPAMPrOaBB5p3CoDUy2KJuwbhie7nk_0nmSFAQooGPBOjTOKbnMg5Xhdg_IUvmoPvni4324joSc5flTbgQJIP79Eem4iVC9Qe9BAthD77gapNA0CNmVSieA=w1920-h1080-s-no-gm
Only a very small difference in belt size, which is negligible
AP1GczMb28l3aqgpFx5Kz51JIdNEiZ3nsPmZzP3LtTYoCpFk9kfp9C-LKMIwongVQ2taa_wj7lfx02gZ6sS98gCyPEf768LC8uYF5xqVCBplPU4LpMjDPpMZmYv1fj9-_edEU_sY0ktrmfOYidLSWmk7VaRflg=w1920-h1080-s-no-gm
Reactions: tracktoy and Mo_86
