Ow not that mk5 Ibiza again.....
t.oldaker
SFS Performance Hoses Rep
Jul 5, 2011
894
Bournemouth
www.facebook.com
Door handles done
Door handles done
t.oldaker
Jul 5, 2011
894
Bournemouth
www.facebook.com
New boot instal
Just finished off and wired up my new boot install.
12 inch JVC dual voice coil sub,
Fli 800w amp running 400w on each voice coil,
Custom made MDF box with sub mounted upside down,
GazEP3
Missing the vtec yo :(
Nov 27, 2009
665
Northern Ireland
I take it you're new to the modifying game? Did you literally just make a box big enough to fill the boot floor and cut a whole in the top? If so it will sound like feck all squared! Sub boxes need to be sized accordingly to the sub being fitted into them. Can't be too big or too small or else the sound will be awful, also the seams of the box need to be sealed with caulk to prevent any air escaping and it helps to fill the bix out with a cotton wool like stuffing to smooth out the sound. That amp is also going to overheat like mad too since it's jammed down the side of the box, there's not enough free air moving around it to discipate the heat it's going to generate so you'll probably find it'll cut out quite often
t.oldaker
Jul 5, 2011
894
Bournemouth
www.facebook.com
Nope the top panel is just a filler underneath there is a box sized and made accordingly which has been sound proofed to give it a better bass. I am new to audio but not modifying so i did get my mate who does it for a livin to help me today with the setting of the eq and wiring. The amp will be remounted on the back of the seat as i understand where it is will cause it to overheat.
GazEP3
Nov 27, 2009
665
Northern Ireland
I would've utilised the floor space and put the amp over to one side under a perspex screen, perhaps with some nice blue neons illuminating it. Or build an angled amp rack to have it sitting up in the corner. Don't think simply bolting it to the back of the seat will look great or be very secure!
Although the back of the seat is metal it's not very thick and you'll only be able to use screws to hold it in place and screws won't stay fixed into a 1mm thick sheet of metal for very long when it's supporting the weight of an amplifier particularly when the car's moving around! Under braking and acceleration the screws will come out in no time and probably cause the amp to smash off the back of the sub.
Matthewd91
MattyD
Jun 16, 2011
734
Gourock
Boot install is looking good, regarding the amp on the back of the seat ive had mine there on this car and my last so thats over 3 years and its never came lose what so ever:)
t.oldaker
Jul 5, 2011
894
Bournemouth
www.facebook.com
Cheers :) Yeh well thats good to know i will see what takes my fancy with where to put it. Atm im just enjoying finally having bass back in my car.
adamb87
cupra gone :(
Feb 13, 2011
1,472
Preston
Had amps screwed to the back of the seat in all my cars and never had a single problem. Would like to do something with mine with all that space under the boot floor.
t.oldaker
Jul 5, 2011
894
Bournemouth
www.facebook.com
Couple of new pictures
Quick update on the car and not allot has changed. I blew up the last JVC subwoofer as the fli amp overcooked it. (known problem with the fli loaded amps) so now im running 3200 watt system with 2 vibe 12".
The front grill has also been pink pin striped like a golf gti mk5. Can't wait for gti international.
t.oldaker
Jul 5, 2011
894
Bournemouth
www.facebook.com
Quick update on the car:
- Rear valance has been wrapped in matt black
- GTI inters tickets have arrived
- Pink fog light tint ordered
- Bmx colour coded same as the car
- roof rack ordered
t.oldaker
Jul 5, 2011
894
Bournemouth
www.facebook.com
Loving the bmx idea, pink rims on the bmx?!?!
I want a surf board for mine haha
looking good there mate, like the colour of the bmx.
Cheers guys :) yeh bmx is going on the roof rack and have some interesting extra mad ideas which is going to turn the whole car on its head.
Try and picture a 'clean rat' look. Mad concept but i'm trying too see if i can make it work. fingers crossed!!!
