SAMS BLACK LCR GT2871 build. THE END :( !!!
sambryant
RoadRunner meep meep
Mar 26, 2009
4,848
Bristol
Nice piece of hardware, whats the cut out on the bolt hole on the collector for though??
Shiny, shiny
thanks m8, its truly a work of art. not to sure why they cut that out, its pretty tricky to fit so it must be to help in some way. if the head is coming off then it will make no difference. just a wild guess :lol:
Ronin225
4,652
22
Worcester
So if the heads coming off is anything being done to that?
1 piece exhaust valves?? porting and gas flowing while your doing rods??
sambryant
Mar 26, 2009
4,848
Bristol
no just the rods and replacing oem parts with oem. i have no plans for going bt. my plan is max out the K04 then go hybrid. i have wmi so that and the mani should work well together :)
i may look into having the inlet mani ported but not sure yet. i dont think at the level of tuning im going for, porting isnt that important.
Ronin225
4,652
22
Worcester
Not considering the 1 piece exhaust valves as the OE ones are know to fail
Broken exhaust valves were the reason i managed to get my BT kit
sambryant
Mar 26, 2009
4,848
Bristol
quiet you im trying to save money lol. every time i think im getting there someone always says have you thought about this? lol Dont know what to do now :(
Ronin225
4,652
22
Worcester
They could be ok on OE rev limit but many maps extend this and if your going hybrid it would be a shame to have to limit it.
I think the guy i got the kit from had them go at 7.2k rpm
I know Phillc has them for his rebuild
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
hello all, just thought i would post my latest goodie :)
its the new version relentless manifold. (will be doing a full review)
pics
i have to say the quality between this new version and the old one is night and day. flanges are flat, welding is spot on and the quality of stainless steel seems better. really looking forward to fitting and seeing how much power can be gained. i have also ordered a few other parts for my engine rebuild. i have the very fancy IE timing belt kit , oem rod bearings and gaskets on the way. Milltek exhaust should be with me tomorrow :)
that xs mani looks much much better
:clap:
sambryant
Mar 26, 2009
4,848
Bristol
:clap:
hello bill just the man i wanted to talk to :D infact just asked you a question on the audi forum. yes the manifold is 100x better than the old one you had at b5. flanges are flat and the quality of welding and stainless used seems so much better :) can i bring it up to your place?
sambryant
Mar 26, 2009
4,848
Bristol
Cool i will get these ordered. May put the build back a couple of weeks but i guess its worth it :) what sort of rpm are these good for?
sambryant
Mar 26, 2009
4,848
Bristol
nice update :)
hello all. time for a update and getting closer to the rebuild.
firstly i will start with my new exhaust system (new milltek) this is my 3rd system now, i hope i like this one
i had a few parts arrive in the post today, rod bearings, timing chain gasket set and engine rebuild lube.
i also order the following parts
supertech exhaust valves
IE timing belt kit with the bling red bit
arp head bolt set
oem water pump and oil pump.
all i need to order now is a full gasket kit and piston rings, iirc.
