Ronin225's Candy rimmed Black LCR - Project 500-4WD, Cage installed and bigger turbo
Ronin225
4,652
22
Worcester
Tubular high flow manifold
Downpipe, decat and racecat
Custom welded aluminium charge pipe
Oil and water lines
Ronin225
4,652
22
Worcester
500cc/550cc injectors
A few different style intake systems
2 Upper vibratechnics engine mounts
Last but not least a room in the house i am decorating become a car part and DIY leftover store room (another LCR interior under the sheet)
Ronin225
4,652
22
Worcester
Cheers, pity i have to wait until the bottom end is done before it can be fitted, but will be worth the wait.
Previous incarnation had this running just shy of 370bhp
Ronin225
4,652
22
Worcester
Seems ok, there is a little play in the shaft but not much
I will send it away to be reconditioned for piece of mind, dont fancy taking it off after not long putting it on
Does anyone know what kind of torque it would run if it was fitted then ran on just actuator pressure??
Would standard rods hold this until uprated or would they be overstressed?
Ronin225
4,652
22
Worcester
I am thinking Bill but just slightly worried if i've had the car corner weighted and have to wind it up to get on the RR
The guy who i bought it off recommends Nick from the company that is banned from here and doesnt appear if you write it
Still undecided at the moment
paul-murphys
efr 6758 here i come
i got a brand new vvt oem unit to fit so once fitted that will decide if going bt or hybrid, im tempted to sell the hybrid setup and stick a gt3071 on but will see how funds go im looking at 4k for a bt setup :(, found 2 piece brakes and ds2500 pads for £570 delivered so will get them and change vvt unit in next few weeeks, also going away with work from aug to oct so that may be my funding for my big turbo :)
when thinking of getting your car sorted? the gt2871 will be awesome :)
Ronin225
4,652
22
Worcester
If you do go BT will a 3071 not be a bit laggy, will make some good figures though
Need to sort out rods and ideally valves before i drop turbo in, i can run the parts in with K04 then keep it safe
I still have bits n pieces to fit and more to buy so cant really see it being on this year
Car will be on a stand at inters if your there sunday
Also dont know if you've seen dannylads different BT setup
