Ronin225's Candy rimmed Black LCR - Project 500-4WD, Cage installed and bigger turbo
Ronin225
4,652
22
Worcester
Cheers guys, should hopefully be ordering my stroker kit at the end of next month
Decided to go bigger displacement instead of just doing rods and isnt that much more expensive
I will be going for the 2008cc kit as this wiil also bring the spool of the turbo lower due to the increased flow over the turbine wheels, should be boosting in the low 3k's
I have got some pics of the leaking area but cant get my phone to link to laptop
Ronin225
4,652
22
Worcester
The pictures
The cable comes up with the rest of the loom and passes just in front of pollen filter as seen here
After this it then runs to almost below the edge of the windscreen where it drops through a hole and grommet that is there originally and where the water was getting in and now is covered in sealant
It comes out behind glove box and down into passanger foot well and is then ran along with the rest of the loom down the side of the car
As the water was going past the grommet it was running along the cable and dropping off in the passanger footwell but then running into the rear as this is a lower point.
I was going to strip the carpet out completely to dry but so much plastic trim has to be removed instead i removed seats and enough to give the carpet enough flexibility to move enough for a good dry out.
Also resealed the passanger door while i was there emptying what now seems to be gallons of water from the sound deadening.
So if relocating the battery that is a good route to take but be careful about sealing the grommet.
Mine has been in a while and assume the cable must have moved slightly and someones foot may have pressed hard on the carpetpulling the cable slightly breaking the seal around grommet. I'll just keep an eye on it now
Ronin225
4,652
22
Worcester
I will keep updating the thread but after the stroker kit arrives it will be slow as its got to get a few miles to bed in before mr garrett goes on
Ronin225
4,652
22
Worcester
Just a few more logs from the current K04, just seeing how healthy the engine is running
Also tagged block 004 on as i was interested in seeing if my stock SMIC are a bit of a choke point even when running an OE map.
First run also pulled bad timing but i am assuming it was heatsoak as we had to wait a while to get a clear run
Code:
	Group A:	'003				Group B:	'020				Group C:	'004
		RPM	Mass Flow	Load	Ign. Timing		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		RPM	Voltage	Temperature	Temperature
	TIME					TIME					TIME
Marker	STAMP	 /min	 g/s	%	 °BTDC	STAMP	 CF	 CF	 CF	 CF	STAMP	 /min	 V	°C	°C
	0.8	2920	92.47	100	11.3	0	0	0	0	0	0.4	2800	13.79	83	37
	2.11	3320	96.17	100	12.8	1.21	3	0	0	0	1.61	3160	13.65	83	33
	3.32	3720	107.58	100	13.5	2.51	2.3	0	0	0	2.92	3560	13.79	83	30
	4.62	4080	114.22	100	18	3.82	2.3	0	0	0	4.22	3960	13.79	83	30
	5.84	4440	127.75	100	18.8	5.03	1.5	0	3	0	5.44	4320	13.79	83	30
	7.15	4800	131.64	100	12.8	6.33	0.8	0	3	3	6.73	4720	13.65	83	31
	8.44	5160	146.39	100	15	7.64	3.8	0	2.3	2.3	8.04	5040	13.86	84	33
	9.66	5480	157.86	100	12.8	8.86	6.8	3	1.5	2.3	9.26	5360	13.65	84	34
	10.87	5760	167.58	100	13.5	10.06	6.8	2.3	4.5	1.5	10.46	5640	13.86	84	35
	12.17	6040	171.67	100	10.5	11.37	6	2.3	3.8	1.5	11.77	5920	13.72	84	37
	13.37	6240	166.86	99.6	15	12.57	5.3	1.5	3.8	0.8	12.97	6160	13.72	84	38
	14.6	6400	166.61	100	15	13.78	5.3	4.5	3	0.8	14.19	6360	13.72	84	39
Thursday	8	September	2011	21:28:56
1ML 906 032 A		1.8l R4/5VT         0002
	TIME					TIME					TIME
	0.5	2840	89.75	100	13.5	0.99	0	0	0	0	0	2720	13.86	78	28
	1.81	3280	95.36	100	14.3	2.21	0	0	0	0	1.41	3120	13.86	78	26
	3.01	3640	104.89	100	16.5	3.52	0	0	0	0	2.61	3520	13.86	78	24
	4.32	4040	116.11	100	18.8	4.82	0	0	0	0	3.92	3920	13.86	79	24
	5.63	4440	126.47	100	18.8	6.13	0	0	0	0	5.21	4320	13.86	80	25
	6.93	4800	137.25	100	18.8	7.34	0	0	0	0	6.53	4680	13.93	80	26
	8.25	5160	145.56	100	18	8.75	0	3	0	0	7.84	5040	13.79	81	27
	9.65	5520	163	99.2	14.3	10.16	0	2.3	3	0	9.25	5440	13.93	81	29
	10.96	5840	171.97	100	13.5	11.36	0	1.5	3	0	10.56	5760	13.79	81	30
	12.27	6120	174.33	99.2	16.5	12.77	0	1.5	2.3	3	11.78	6000	13.93	81	32
	13.56	6360	171.94	99.6	16.5	13.98	0	0.8	2.3	3	13.17	6280	13.86	82	34
Just out of interest what are classed a s good IAT's too??
sambryant
RoadRunner meep meep
Mar 26, 2009
4,848
Bristol
when it comes to intake temps, take idle temp, then see the max temp on a power run. its the temp difference hear that shows how well a intercooler is working. iirc mine goes up by 10 degrees on a power run on stage 2, also thats on a rolling road.
Ronin225
4,652
22
Worcester
Had a trip over to see the ever knowledgeable mr phill and fit some bits
We decided to start with the biggest and most difficult job, the poly rear beam bushes
So after undoing all the brake lines and removing calipers and unbolting coilovers
The rear beam was free
As you can see the splash guards were left on as the only way to remove them is to remove the hub which is lots more work
The old bushes knocked out with surprising ease as we were expecting these to put up a bit of a fight but within 2 minutes, out
Then the more difficult part of getting the new ones in which definitely requires 2 people with some clamps to get them in, due to the tight fit they kept trying to twist on insertion but after they engaged by 25mm ish they could be knocked home with a 4lb screwdriver
So a nice fully poly bushed rear beam
Then the reassembly process obviously in reverse of the disassembly and how it should look with the rear beam all bolted up with the new bushes in
The brakes were then bled, only the rear calipers were done as the pipes were clamped when taken off and most of the air shouldnt have gone back through the system and the peddle feels nice and firm.
Just before putting the rear wheels back on i thought it would be a good time to put the rear spacers on that i have had for the last 6 months.
So an additional 20mm track width has been added to the back
Still more to fit so will be back to see Phill tomorrow to fit the vibratechnic engine mounts and the forge shortshift, so will update then
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
Nice work bud!
How does it feel with the bushes?? I can't wait to get all mine done one day soon.
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
Nearly a member of the fully pollied club Tim, just the rack bush to go, but it great isn't it it never fails to put a massive grin on my face when going around corners, until the esp cuts in that is.
Ronin225
4,652
22
Worcester
Funnily enough the ESP daemon hasnt reared its head in this very stiff setup yet so fingers crossed
Also i cc'd you on the INA email
Ronin225
4,652
22
Worcester
Just to post up how sundays work went and unfortunately pics are fitted parts only mainly due to me forgetting to take any whilst working:doh:
Undertray removed and a jack to support each side of the engine was used as each mount was replaced. The original bolts were reused and done up to f'ing tight N/M due to the fact we couldnt find the recommended torque settings.
I will probably replace the bolts soon and correctly torque them (if anybody knows these it would be handy)
After that the forge shortshift was fitted and the gear linkages reset to suit
Heres what was removed, ready to be added to a large pile of OE bits in the garage
While sensibly driving home the shortshift is very noticeable and travel is hugely removed, slightly more effort required to engage it into gears though
Later in the evening i had a B road blast and i cant believe how much it sticks to the road, almost go-kartesque
There is definately more vibration in the cabin and you can feel engine vibration through the pedals too.
Engine note in the car has changed and everything feels very stiff and firm.
From a personal point of view the engine mounts i think made the biggest difference, could be just a sensory thing, but would definitely recommend to anyone
Took barn for a little trip in it too, giving him ideas
