Ronin225's Candy rimmed Black LCR - Project 500-4WD, Cage installed and bigger turbo
cupra-barn
It's all about stealth!
Aug 4, 2010
2,109
Worcester
Courtesy of Tom bud :)
Ronin225
4,652
22
Worcester
Another small update
Tyres on the front are a little close to the limit and after seeing the vred's were on offer i got a pair
Was originally going to go with the AD08's since they get great reviews as a road going super sticky track tyre but at 60 quid a corner more than the vred's with the offer on i couldnt justify it
Was woken up by the delivery man this afternoon with these, just squeeze the last bit of life out of the asymetrics now
cupra-barn
Aug 4, 2010
2,109
Worcester
Tim....Where?!?
Ronin225
4,652
22
Worcester
Nice one Tom, it sure was looking clean back then (not so much now though)
May have to get you to come and do it again before the winter and gritted roads
Ronin225
4,652
22
Worcester
Small update again
Bought a vagcom cable in the weekso thought i'd try it out and popped over to see barn to do some logging and here are the results
PHP:
Saturday	20	August	2011	22:38:10
1ML 906 032 A		1.8l R4/5VT         0002
	Group A:	'003				Group B:	'020				Group C:
		RPM	Mass Flow	Load	Ign. Timing		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
	TIME					TIME					TIME
Marker	STAMP	 /min	 g/s	%	 °BTDC	STAMP	 CF	 CF	 CF	 CF	STAMP
	0.01	3080	89.42	82.4	18	0.4	3	0	0	0
	0.82	3320	98.19	100	11.3	1.21	3	0	3	0
	1.62	3600	105.92	100	12.8	2.01	2.3	0	3	0
	2.41	3840	110.53	100	14.3	2.81	2.3	0	3	0
	3.23	4080	117.5	100	15.8	3.73	1.5	0	2.3	0
	4.13	4360	126.19	100	16.5	4.64	1.5	0	2.3	0
	5.04	4600	131.94	100	15.8	5.44	1.5	0	1.5	0
	5.84	4840	136.86	100	17.3	6.24	0.8	0	1.5	0
	6.64	5080	146.17	100	16.5	7.04	0.8	0	0.8	0
	7.45	5280	155.11	100	16.5	7.95	0	0	0.8	0
	8.35	5520	165.19	99.6	17.3	8.86	0	3	0.8	0
	9.26	5720	171.36	100	13.5	9.66	0	3	3	0
	10.16	5960	175.97	100	17.3	10.57	0	2.3	3	0
	11.07	6120	171.97	100	15.8	11.47	0	2.3	2.3	0
	11.87	6280	168.56	100	18.8	12.27	0	1.5	2.3	0
	12.69	6400	171.67	100	19.5	13.09	0	1.5	1.5	0
	13.49	6560	170.39	100	19.5	14	0	1.5	1.5	0
Saturday	20	August	2011	22:40:30
	TIME					TIME					TIME
	0.01	2880	60.47	34.9	25.5	0.4	0	3	0	0
	0.8	3120	102.08	100	11.3	1.2	0	3	0	0
	1.6	3360	97.78	100	15.8	2	0	3	0	0
	2.4	3600	102.75	99.6	16.5	2.82	0	2.3	0	0
	3.21	3880	111.56	100	15	3.61	0	2.3	0	0
	4.01	4120	119.97	100	16.5	4.42	0	1.5	0	0
	4.93	4400	127.17	100	13.5	5.33	0	1.5	0	0
	5.73	4600	131.28	100	18	6.13	0	0.8	0	0
	6.53	4840	139.64	100	17.3	6.93	0	0.8	0	0
	7.34	5040	143.31	100	16.5	7.84	0	0.8	0	0
	8.24	5320	154.69	100	17.3	8.75	0	0	3	0
	9.15	5560	166.03	99.6	15.8	9.55	0	3	3	0
	9.95	5720	172.25	99.6	15.8	10.35	0	3	2.3	0
	10.77	5920	173.39	100	13.5	11.26	0	2.3	2.3	0
	11.68	6120	173.11	99.6	17.3	12.16	0	2.3	2.3	3
	12.56	6280	170.81	100	18	12.97	0	2.3	0.8	3
	13.37	6400	167.97	100	18.8	13.79	0	1.5	0.8	3
	14.19	6520	169.97	100	20.3	14.68	0	1.5	0.8	1.5
	TIME					TIME					TIME
	0.38	3000	74.86	98	12.8	0.8	0	0	0	0
	1.29	3240	96.56	100	9	1.69	0	0	0	0
	2.09	3520	101.19	100	15.8	2.49	0	0	0	0
	2.91	3760	108.19	100	15.8	3.31	0	3	0	0
	3.71	4000	114.33	100	17.3	4.11	0	3	0	3
	4.51	4240	120.36	100	15.8	5.02	0	2.3	0	3
	5.42	4520	128.86	99.6	20.3	5.82	0	2.3	0	2.3
	6.32	4760	135.31	100	18	6.72	3	1.5	0	2.3
	7.13	5000	144.31	100	13.5	7.53	3	1.5	0	1.5
	7.93	5200	148.89	99.6	15	8.33	3	1.5	3	1.5
	8.73	5400	157.08	100	14.3	9.13	2.3	3.8	3	1.5
	9.55	5600	166.31	100	12.8	10.04	2.3	3.8	3	0.8
	10.44	5800	171.67	100	14.3	10.96	1.5	3	2.3	0.8
	11.36	6000	173.97	100	12	11.87	1.5	3	2.3	0
	12.36	6200	173.11	100	12	12.76	0.8	2.3	1.5	0
	13.18	6360	167.22	100	20.3	13.66	0	1.5	0	3
Airflow is slightly lower than i expected but works out to be producing about 220bhp
Correction factors dont seem too bad but i do notice that i am getting 3's right from initial WOT on some of the runs, i thought it was mainly higher revs would pull the CF's??
Any vagcom gurus have any feedback on them?
cupra-barn
Aug 4, 2010
2,109
Worcester
And what a fun evening it was, I saw you go for the grab handle coming up to the roundabout lol
No serious thanks for coming over mate was great.... Me and my 197.7! :D
RDS
OEM+
Aug 11, 2010
2,276
11
Newcastle upon Tyne
I'm no expert mate but I've done a few logs on mine today and I'm getting CF higher up the range. However if you look at the revo sps guide page 15 shows CF at lower rpm as load tends to be higher there on higher gears. :confused:
Ronin225
4,652
22
Worcester
An interesting read, seems ok to pull the low CF's at this rpm in 4th then
I should have added block 004 on some of the runs as i still use the stock SMIC and would be interesting to see what AIT were.
I notice your log look very good not pulling any CF's until right at the end
Ronin225
4,652
22
Worcester
Went out for a drink last night with my mate and noticed when i hopped in the car the swimming pool in the back passenger footwell.
Had this not too long ago and the door seal had gone so replaced and all was good for a while
Anyway after heav rain last night loads of water again this morning but after removing some trim i have found the problem.
Next to the pollen filter under scuttle panel is a grommet which i ran the cable for the battery relocation through and was given an extra bit of sealer around too but something must have disturbed this recently as the water was running down the cable and into car.
Just a word of warning for those who maybe doing this too
Will try to rip it all out tomorrow get some pics and weather dependant whack more sealant round it
