Ronin225's Candy rimmed Black LCR - Project 500-4WD, Cage installed and bigger turbo
Ronin225
4,652
22
Worcester
Cheers tom, not a million miles away from corner weighting now
Maybe you should move closer to me, phillc is very close too
Cheers Dolby, car looks dirty and has done for the last 6 months, black is a pain to clean
On a side note the battery was relocated last night (cheers phill, hope the wife wasnt too piss off)
Will get some pics up tomorrow after tidying it up and refitting everything
Huge green cone on the cards from bill is very close now!
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
Corner weighting aswell - great stuff. This car will be wired!
Looking forward to the pics of the battery relocation and that infamous cone when that turns up. Will you be logging airflow with it on vagcom bud?
Ronin225
4,652
22
Worcester
Relocation update
Monday afternoon i popped over to see mr phill and we set about the task of getting the battery out of the bay.
Didnt seem too big a job until you hit the point of no return, say no more
Then the amount of interior that has to be removed is quite a lot too
Here is phill after i told him there was a celine dion CD in the glove box (or maybe he was just removing it, take your pic?)
With cable ran through phill started on the distribution block and i set about wiring the kill switch and mounting the box into the boot
Not many pictures towards the end in the evening as it was dark and needed a few bits sprucing up, but it lived!
Ronin225
4,652
22
Worcester
After being home from work early the last few days i have set about finishing it off
The bay with the gapping hole, hmmm. wonder what i could fill that with later?
Side view to see how much room it trakes up
Then a new ground terminated in the boot and all cabling out of site, a quick trim of the boot carpet and viola
Then put the seats back in and a nice custom install finished
Probably the only leon to run an inline kill switch but i think its a nice little touch
Anyway the front end is noticably lighter and will need some adjustment on the coilovers to set this properly again.
Cranks fine but the extra cable length is obviously draining the battery more and can be seen on the cluster lights when starting but all in all a good job
Hats of to phill though as it would have taken me absolutely ages otherwise
Ronin225
4,652
22
Worcester
Staining looks worse on the photos, barely noticeable in the flesh and its not what you think it is either
I know its sad when you laugh at your own jokes but that pic of you furtling around the glovebox makes me laugh
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Nice battery relocation, i am very very interested in doing this, don't suppose you have a list of cable and stuff needed for the wiring?
Also where did you run the wires through the cabin?
Murdered LCR
Wide mouthed mofo
Sep 9, 2006
6,646
8
Murder Inc.
Rs smith you run the cable down the passenger side use 4awg I have also done the battery relocation just waiting on my battery cage which should be here weds
Ronin225
4,652
22
Worcester
There is a small channel that most of the electrics run down on the passanger side which the cable can be run in, this easily allows to the grommet behind scuttle and through rear seatbelt cover into boot
If you dont want to pay lots for car power cable due to its increased cost look into machine power cable at about 20-25mm square
I used Radox cable used in CNC machines and solar power installs, also can take high spikes in current where it would have DOL motors which is ideal for intial cranking
I think the isolator is also a nice touch too.
Dont forget to get some cable lugs too
Ronin225
4,652
22
Worcester
Chees guys, will try get some pics too
I have a few ideas for some bits Forge maybe able to adapt to fit a leon so will have a chat whilst there tomorrow
