Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
You do realise you havent paid me for anything yet so it still belongs me:lol:
Oh i see, like that is it...:bleh:
That was two weeks ago :p
I know nothing has happened :cry: no parts from INA and no head, the bloke says he has posted it three times now, i have passed it on to paypal.
Impressive stuff Phil! Following this closely. Did you find an answer to your DV problem? Sounds like it's not opening if you're getting a flutter / chatter?
Thanks Ape, so thats what causes the flutter is it? i did service the DV a while back? it all started after it had been sat while i was on holiday and now comes and goes, i will check the DV again.
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Thanks for all the kind comments lads. Well a bit of an update, my head has arrived along with the IE bits.
I also picked up some bits and bobs when i went to look over an LCR that is being broken near me, it had only done 36k as well (I had the fuel pump from it too) as the engine was out i noticed that the brake lines going from the master cylinder to the ABS pump where quite a bit bigger than the ones on the LC so i bought them and the master cylinder and the ABS pump, i am assuming they are bigger due to the Brembos, i have also got some more black silicon hoses to replace the red ones water ones, all of which i will change when the engine comes out. I am just waiting on a new cam belt pulley and then i can drop the flywheel and pulley of to be balanced with the crank and the head to be rebuilt although it will all come to a stop again until the bits from INA turn up??
I have also been messing with the engine bay again LOL.
I have also replaced the piston and "O" rings in the DV (Forge Used to give these free £17.00 now!!) just thought you may be interested in the wear after a couple of years, you can feel the ridges in it too.
So just waiting on the bits from INA which has really held the build back quite disappointed really.
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
I got mine free by emailing them my screen name on here.
Wonder why it's worn?
