Cupra R - Forge Remap Logs....feels slow
leon cupra r
Back in an LCR!
Nov 10, 2009
902
Barnsley
These are also from earlier...
Few CFs in first run, but to be expected when going from under 2k really!
2nd log I think is in 2nd gear, (I left it logging for ages, just had a scan through for a section with a reasonable run from low-high revs) and shows my CFs more realistically.....
you think the timing is being pulled back because the mixture is too lean resulting in hotter cylinder temps + therefore more knock?
8bit
3,401
Aberdeen
Think those have come out a bit funny, not certain what's all being measured in the second block? First one is showing some corrections still, think possibly a bit worse than in your original logs?
8bit
3,401
Aberdeen
Possible I suppose but that's pushing the limit of my knowledge on this. Hopefully someone else can jump in!
Have you checked to see that your injectors aren't leaking? The top of the inlet ports on your intake manifold will seem to be wet/oily if they are. Could be worth checking the injectors aren't blocked too, obviously be careful to clean around them before removing so bits of dirt don't fall into the cylinders.
Have you checked the vac line going to the top of the fuel pressure regulator also?
leon cupra r
Back in an LCR!
Nov 10, 2009
902
Barnsley
just edited to show values, sorry about that!
Yeah there are a few CFs, but the top one, acellerating in 5th from 1800rpm, the cylinders are gunna get pretty warm! so a few are to be expected really....
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
very very lean is that..... maf looks low aswell for mapped ko4... seen another log with a forge map with lean fuelling requests.. or was this the same one??
leon cupra r
Back in an LCR!
Nov 10, 2009
902
Barnsley
was probably mine, first post in this thread... Chris GTL logged it originally for me...
Any idea what could be causing it james? you use unisettings right? rekon its worth turning up the fuel enrichment on this and relogging, to see whether or not the fuel pump/injectors can actually provide enough fuel to richen out the mix - find out if its a request or a supply problem?
If so... primary fuel enrich, or secondary fuel enrich??? which one should I change?
james walker
May 24, 2007
5,121
retford notts
i wouldnt mess with unisettings when requested is lean tbh mate. id go back to forge and ask them to check it out on dyno first. your cfs arent too bad tbh, but fuelling is a concern. also maf reuest looking low.
8bit
3,401
Aberdeen
I guess what we're hoping to see is the fuelling richening up as the revs (and thus cylinder temps) rise, thus stopping the CFs. What's interesting in my case is that I don't see any CFs but yet my fuelling isn't richening up either. Now your car has caught whatever ailment mine has!
James, I don't have a Forge map (or any remap AFAIK) but mine is doing the same as this one, maybe that's what you're thinking of? I know you've posted in my thread too. Note that these logs here don't go all the way up to redline,
@ leon cupra r, still could do with seeing Block 032 readings while sitting with engine off but power on. Also, did you get the Forge remap or was it already on the car? If you got it then could be worth speaking to Forge?
leon cupra r
Back in an LCR!
Nov 10, 2009
902
Barnsley
Left a log running on block 003 on way home just to see what MAF peaks at... highest value in there was 195.58gs... which is more like it, but even this is a bit lower than you would expect....
I couldnt remember the order of blocks you said to log 8 bit, so I made it up as I went along lol... heres the results
Code:
		RPM	Temperature	Load	Absolute Pres.		Lambda Factor	Lambda Factor
	TIME					TIME
MARKER	STAMP	 /min	°C	%	 mbar	STAMP
	0.85	3000	23	75.7	2040	0.45	0.922	1
	1.65	3280	22	71.4	2220	1.25	0.961	0.953
	2.56	3640	21	71	2140	2.07	0.953	0.953
	3.47	3960	22	70.2	2110	2.96	0.961	0.953
	4.37	4280	23	70.2	2060	3.97	0.938	0.953
	5.18	4560	24	69	2020	4.77	0.938	0.953
	5.98	4800	24	68.2	2020	5.58	0.945	0.953
	6.78	5080	26	68.6	2000	6.38	0.953	0.953
	7.58	5280	27	67.5	1950	7.18	0.922	0.953
	8.4	5520	27	67.5	1960	8	0.953	0.953
	9.2	5720	29	65.9	1930	8.8	0.945	0.953
	10.11	5920	30	65.5	1910	9.6	0.93	0.953
	10.91	6120	30	64.3	1840	10.51	0.922	0.953
	11.71	6280	32	63.9	1870	11.33	0.922	0.953
	12.62	6440	33	63.5	1850	12.22	0.953	0.953
	13.54	6560	33	62.4	1830	13.04	0.945	0.938
	14.43	6720	33	60.8	1790	13.94	0.906	0.906
	15.34	6800	34	61.6	1770	14.94	0.899	0.867
	16.25	6880	34	59.6	1860	15.84	0.813	0.844
Code:
	Group A:	'003				Group B:	'020
		RPM	Mass Flow	Load	Ign. Timing		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
	TIME					TIME
MARKER	STAMP	 /min	 g/s	%	 °BTDC	STAMP	 CF	 CF	 CF	 CF
	0.86	3240	120.69	100	13.5	0.37	0	0	0	0
	1.68	3600	122.19	100	9.8	1.26	0	0	0	0
	2.48	3960	136.58	100	11.3	2.08	0	0	0	0
	3.28	4280	145.06	100	16.5	2.88	0	0	0	0
	4.08	4600	150.44	100	17.3	3.68	0	0	0	0
	4.99	4920	157.56	100	18	4.49	0	0	0	0
	5.9	5240	165.42	99.6	18.8	5.39	0	0	0	0
	6.7	5480	172.72	100	20.3	6.3	0	0	0	0
	7.52	5720	177.14	99.6	15.8	7.1	0	3	3	0
	8.41	5960	176.86	100	16.5	8.01	0	3	3	0
	9.23	6120	172.25	100	20.3	8.81	0	2.3	3	0
	10.03	6280	174.81	100	21	9.61	0	2.3	2.3	0
	10.92	6400	175.97	100	20.3	10.43	0	2.3	2.3	3
	11.72	6480	174.81	100	16.5	11.32	3	4.5	1.5	6
	12.54	6560	172.81	99.6	21.8	12.14	3	4.5	4.5	6
	13.34	6600	167.44	99.6	20.3	12.94	2.3	4.5	4.5	5.3
	14.23	6680	164.42	100	23.3	13.75	2.3	3.8	4.5	5.3
	15.05	6720	164.11	99.2	22.5	14.65	2.3	3.8	3.8	5.3
This run was up a hill, really started to struggle about 6200rpm, felt like it was dyeing when those CFs started creeping in... I did advance the timing with unisettings though so that would explain why theres more CFs than previously... might turn this back a touch tomorrow...
Fuelling was hitting 0.8xx on that run!!! dont know whats changed but thats more like what we need aint it james?
james walker
May 24, 2007
5,121
retford notts
still very lean.
riches out at the end, but would like to see0.8xx from 5k onwards really.
pull timing to zero until fuelling sorted out
leon cupra r
Back in an LCR!
Nov 10, 2009
902
Barnsley
OK mate will do that tomorrow....
Yeah I thought it should probably be richening earlier on, but at least it is riching out a little bit!!
Forge dont have rollers so it was just a generic re-flash when they mapped it...
you said MAF request was looking low? Is there a maf request log or was that just a typo?
leon cupra r
Back in an LCR!
Nov 10, 2009
902
Barnsley
Code:
	TIME					TIME
	0.6	3000	98.17	100	14.3	0.99	0	0	0	0
	1.41	3240	113.92	100	6.8	1.81	0	0	0	0
	2.21	3520	119.47	100	9	2.71	0	0	0	0
	3.11	3760	125.81	100	11.3	3.52	0	0	0	0
	4.02	4040	134.25	100	12	4.42	0	0	0	0
	4.93	4280	141.11	100	13.5	5.43	0	0	0	0
	5.83	4520	144.86	100	15	6.23	0	0	0	0
	6.63	4680	147.19	100	13.5	7.04	0	0	0	0
	7.54	4920	155.78	100	14.3	7.94	0	0	0	0
	8.34	5120	159.25	100	12.8	8.75	0	0	0	0
	9.25	5320	168.19	100	12	9.65	0	0	0	0
	10.05	5480	169.17	100	14.3	10.45	0	0	0	0
	10.87	5520	58.47	11.8	15.8	11.36	0	0	0	0
	11.76	5200	10.42	7.8	5.3	12.16	0	0	0	0
	130.35	3160	97.58	100	18.8	129.93	0	0	0	0
	131.25	3520	123.75	100	5.3	130.75	0	0	0	0
	132.04	3840	131.64	100	6.8	131.64	0	0	0	0
	132.96	4200	141.89	100	12	132.46	0	0	0	0
	133.76	4480	147.17	100	13.5	133.36	0	0	0	0
	134.57	4760	151.03	100	14.3	134.16	0	0	0	0
	135.47	5040	162.44	100	15	135.07	0	0	0	0
	136.38	5320	171.06	100	14.3	135.98	0	0	0	0
	137.18	5480	173.06	100	13.5	136.78	0	0	0	0
	137.98	5680	174.81	99.6	14.3	137.58	0	0	0	0
	138.8	5800	175.11	100	12.8	138.38	0	0	0	0
	139.6	5920	175.11	100	17.3	139.2	0	0	0	0
	140.41	6040	178.58	100	17.3	140	0	0	0	0
	141.31	6160	176.25	99.6	16.5	140.91	0	0	0	0
	142.12	6240	172.53	100	18	141.71	0	0	0	0
	143.12	6360	178.31	100	19.5	142.62	0	0	0	0
	144.03	6440	179.78	100	19.5	143.63	0	0	0	0
	145.02	6600	178.03	100	20.3	144.54	0	0	0	0
	145.83	6680	175.42	100	20.3	145.43	0	0	0	0
	146.65	6760	175.97	99.6	21	146.23	0	0	0	0
	147.55	6880	179.78	99.2	18.8	147.05	0	0	0	0
	148.35	6760	9.03	10.2	9	147.95	0	0	0	0
	149.24	6320	14.33	9.8	9	148.76	0	0	0	0
	150.06	5920	13.5	9.8	7.5	149.66	0	0	0	0
put the timing back today mate... should be getting new CTS tomorrow just incase the one I've got at the min is still playing funny games... also will probably pull the plugs out and check them after the last set ended up black as the night....
8bit
3,401
Aberdeen
OK that's looking a bit better, no CF's anyway - can you log block 031 again now and see if the fuelling's changed any?
Airflow is still low tho, looks like you're making about 224bhp, or at least that's what your airflow is good for. Have you got an OEM airbox, snorkel and a panel filter you can try? I only gained about 2 or 3 g/s swapping my airbox and Pipercross panel filter for a big Jetex cone, am wondering if maybe some cars just don't respond well to big Jetex cones...
Be interested to find out if changing the spark plugs makes any difference, I'm getting mine done tomorrow so fingers crossed...
leon cupra r
Back in an LCR!
Nov 10, 2009
902
Barnsley
I think my old airbox is in the cupboard... will try dig it out and try tomorrow....
I have a piece of 3inch metal tubing running from where the old airbox used to draw the feed behind the headlight up to next to the jetex... I'm unsure how much benefit (if any) this provides, although its not covering any of the filter so should not be restricting it.
Yeah I reckoned it to be back around 225bhp... pretty poor for a mapped car!
The plugs have literally only been changed between 1-2 months ago so SHOULD be fine, although the state of my last ones makes me wonder if theres something wrong...I'm hoping it was just the CTS making the engine chuck loads of extra fuel in on occasions leaving them covered in soot, but hopefully will see tomorrow. Get a new CTS on there to rule this out the equation in the future too.
I know it sounds horrible but I'm glad youre having similar problems 8bit! double the chance of finding the fix! lol
Oh and regarding the airbox/jetex, it definately felt better when I stuck the Jetex on, so I'm not holiding up much hope for increased MAF readings with the box tomorrow....
leon cupra r
Back in an LCR!
Nov 10, 2009
902
Barnsley
Block 032 with engine off shows 0.0% on bank 1 and -1.6% on bank 2.... what does that mean ? lol
I am just going out now to do a log of fuelling
leon cupra r
Back in an LCR!
Nov 10, 2009
902
Barnsley
after a run its showing -3.9% altho i had to fill up on sainsburys 97 octane instead of v power today so i presume this is why...
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
Code:
	TIME					TIME
Is this back at 0 timing Ben?
What spark plugs are you using at mo?
leon cupra r
Back in an LCR!
Nov 10, 2009
902
Barnsley
Yeah thats with timing back at 0 in unisettings...
Im using... I think they are bosch ones, standard temp grade. I just went and got whatever the computer recommended for our cars at GSF after I had problems with the last batch that were a grade colder than standard. Seeing as I am wanting to advance the timing when its all sorted I will probably give colder plugs another shot....
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
Hmmm. I'm using NGK standard temp ones and my timing is not as good as what i'd like it to be.
Might give Bosch another try!!
