LCR Logs
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Code:
	RPM	Mass Flow	Load	Ign. Timing		RPM	Load	Absolute Pres.	Absolute Pres.
TIME					TIME
STAMP	 /min	 g/s	%	 °BTDC	STAMP	 /min	%	 mbar	 mbar
0.4	2240	42.28	90.2	18.8	0.01	2160	77.4	2010	1020
1.31	2560	61	95.3	15	0.91	2400	100.8	2100	1290
2.32	3000	110.86	100	0.8	1.81	2760	134.6	2080	1660
3.12	3480	149.56	100	3	2.72	3200	191.7	2120	2420
3.92	3920	140.06	100	6	3.52	3720	191.7	2160	2300
4.83	4440	154.69	100	12	4.43	4200	175.9	2180	2150
5.63	4880	161.36	100	9.8	5.23	4640	178.9	2190	2110
6.43	5280	181.72	100	12	6.03	5080	177.4	2190	2080
7.34	5720	189.39	100	12	6.85	5480	177.4	2220	2160
8.14	6040	191.86	100	12.8	7.74	5880	163.2	2190	2140
8.96	6320	190.61	100	15	8.54	6200	162.4	2100	2110
9.95	6640	192.78	96.5	14.3	9.47	6520	154.1	2010	1970
Code:
Group A:	'032				Group B:	'118
	Lambda	Lambda	Bin. Bits	Bin. Bits		RPM	Temperature	Load	Absolute Pres.
TIME					TIME
STAMP	%	%			STAMP	 /min	°C	%	 mbar
0.01	-1.7	-1.6	        	        	0.4	2480	39	95.3	1290
0.9	-1.7	-1.6	        	        	1.41	2840	37	94.1	1770
1.9	-1.7	-1.6	        	        	2.3	3280	37	66.7	2540
2.81	-1.7	-1.6	        	        	3.31	3880	36	60	2190
3.71	-1.7	-1.6	        	        	4.11	4280	36	62.7	2190
4.53	-1.7	-1.6	        	        	4.93	4680	37	69	2100
5.33	-1.7	-1.6	        	        	5.73	5080	39	77.6	2170
6.13	-1.7	-1.6	        	        	6.64	5560	40	82	2170
7.04	-1.7	-1.6	        	        	7.44	5880	42	95.3	2120
7.84	-1.7	-1.6	        	        	8.24	6240	45	93.7	2070
8.64	-1.7	-1.6	        	        	9.05	6520	47	89	1950
9.56	-1.7	-1.6	        	        	9.96	6800	50	31.8	2100
Code:
Group B:	'020
	Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
TIME
STAMP	 CF	 CF	 CF	 CF
0.34	0	0	0	0
1.24	0	0	0	3
2.15	0	0	0	3
3.06	0	0	0	2.3
3.96	0	0	0	2.3
4.76	0	0	0	1.5
5.57	0	0	0	1.5
6.37	0	0	0	0.8
7.17	3	3	3	0.8
7.99	3	3	3	0
8.79	2.3	3	2.3	3
9.59	1.5	2.3	2.3	6
LCR 02 - Storm Map - Forge DV - Cat Back exhaust- TIP - Open Filter
Would say car boosting right and maf reading is right of 192 M/s?
seatcupramad23
kc4even23
Sep 7, 2009
3,239
birmingham
200-212 g/s, because with comparison , with logs i've seen on other k04 cars 0.6 bar of boost at 3000rpm is low should be around 1 bar by then full boost at around 3200-3400 rpm
Jul 4, 2010
2,170
Cambs
The g/s readings are probably about right for that boost level tbh.. the reason it looks a little laggy is the that most maps request an unachievable amount of boost low down to spool it up quicker..
Could also add a bit more timing if you ask me
Big_daddy
Oct 20, 2006
3,930
Brummy
OH yeh i see, yeh get full boost @ 3k and duty quite high too when at that rev range.....must vac leak as dv is not that loud- just about hear it , compared to ibiza.
It looks like a very tame map to me only requesting 1.1/1.2 bar boost..
yeh not aggressive but has abit of peak, ...... can feel torque on it....
Big_daddy
Oct 20, 2006
3,930
Brummy
thats what i was thinking as if this was running 1.5 boost it should achive near 200 g/s or more, yeh shame this not tweakable via CC settin/lemminwink crank up timing :)
Big_daddy
Oct 20, 2006
3,930
Brummy
Just found out its a remap from superchip (previous owner ), disappointed with it :( , guna have it reflashed to some one else ....
