It should be somewhere in this thread of other thread.hello, i'm looking for the trick to memorized high beam last setting. Thanks
I have not understood. could you please explain better?Its software version and hardware off AID no coding
Bummer. See if I can sell this on first then. Thanks for the replyNope, you need ODIS, OBDEleven, or VAGCOM. You decide how much money you would like to spend on this.
Login 20103Thanks a lot for your answer !
Regarding points 2. and 3., do you know the exact coding to do ?
I would also like to know if it is possible to add automatic aid to the change of track, to exceed on the highway for example ?
Thanks in advance
cant code this partThanks man. With this setting do you get the warning every 10 seconds of put hand on steering wheel?: THIS ACTIVATES A SORT OF TRAVEL ASSIST. TO WORK, THE LANE ASSIST EARLY MUST ALSO BE CODED AND THE ACC MUST BE ACTIVE WITH THE SET SPEED. IT ALSO WORKS UNDER 60 KM/H.
couldnt code this part on my 2020 first edition err0r 31, any ideas??Hi, I'm Italian, I share with you what I discovered:
EMERGENCY BRAKE SYSTEM
- Select Module A5 (Driver Assistance)
- Select Long Coding
- Select Emengecy Assist
- Set To EA Variant 4
CUPRA VIEWER and CUPRA STYLE
1/ Adding new views to cockpit
- Cupra View on Leon FR
- Select Control unit 17
- Select Adaptation
- Select View Activation
- activate view 6/7/8 the others are useless
2/ Adding all view Cupra on display and infotaiment
- Select Control Unit 17
- Select Start Screen
- Select Version 2
- Select Lap counter
- Set to Yes
- Select Vehicle variant
- Set to Derivative 6 (this Cupra Sporturer)
- Set to Derivative 4 (this Cupra Hachback) - Select Multimedia 5F
- Select Long coding
- Select Car Bodystyle addition
- Set to 1
- Select Vehicle type power stage 2
- Set to Yes
- Select Adaptation
- Select Function configuration hmi
- Select skinning
- Set to 2
- Select HC Variant
- Set To Variant 1
- Select Adaptive Cruise control
- Select PACC Reaction to end of Traffic Jam
- Set to Regulator adaption with speed adaption
- Select PACC regulation on priority
- Set to Active
SCANDINAVIAN DRL
- Select Central Elettric 09
- Select Adaptation - Select Daytime running lights
- Select Tagfahrlicht-Dauerfahtlicht aktiviert zusaetzlich standlicht
- Set To Active
ONLY DSG - AUTOMATIC DOOR RELEASE WHEN THE P BUTTON IS PRESSED
- Select Adaptation - Select Zv Autolock
- Select automatic unlock nar
- Set to Active
DEACTIVATES ENGINE IGNITION WITH STEERING WHEEL MOVEMENT
- Select Module 44 (Sterring Assistance)
- Select Engine start through power steering
- Set To Not active
DEACTIVATES ENGINE IGNITION WITH VEHICLE MOVEMENT THAT BEFORE YOU. IF ACC IS ACTIVATED, THE MOTOR WILL RE-ACTIVATE DESPITE THIS SETTING
- Select Module 13 (Adaptive Cruise Control)
- Select Adaptation
- Select Expanded restart function
- Set To Off
ACTIVATE FOG LIGHTS WITH HIGH BEAM FLASHING
- Select Adaptation
- Select LEUCHTE 12 NL L B45
- Select Lichtfunktion D 12
- Set to Lichthupe
- Select Dimmwert DEF 12
- Set to 100
- Select LEUCHTE 13 NL R B5
- Set to Lichthupe
- Set to 100
ACTIVATE OEM ANTI THIEF ALARM WITH HORN AND DIRECTION INDICATORS
- Select Adaptation
- Select Diebstahlschutz Schnittstelle
- Select DWA verbaut
- Set to installed
- Select Diebstahlschutz.Modulsoftware
- Select Akustischer Alarm ueber Hupe
- Set to Active
- Select Anti.theft blinkers by inter.door handle activ.
- Set to On
- Select DWA campermode
- Set to Active
- Select Dynamic turn signal control
- Select Theft flashing
- Set to active
Good evening, it is possible to see this screen on the display without having the capacitive steering wheel, thanksIs there a way to get the same dashboard display that Travel Assist gets without Travel Assist, where you can see the vehicles around you? I don't worry too much about functionality, it just looks great.
