OBD Modifications
mysticscalex
14
10
hello, i'm looking for the trick to memorized high beam last setting. Thanks
It should be somewhere in this thread of other thread.
basically this is coding:
(Attachment)
do remember that when lights are turned off the high beam assist also turns off again. So it works, but not like desired.
donzi84
18
13
hello,
in internet I have found this photos, range with the blue backgroud but navigation with the black backgroud. Someout have this set up? I have blue backgroud for both the 2 lateral screen. Thanks.
Aug 3, 2024
Hello everyone, I'm new to this forum and French, so I'm sorry for the bad Google translation.
I have several questions for coding with OBD11 :
1. I use the speed limiter very often, but each time I start the car, it is always the ACC regulator which is activated by default, and I have to go through the cruise control menu to activate the limiter. Is it possible to make the car stay in the previous state of the regulator/limiter choice ? And if so, how to do the coding ?
2. I don't have the factory alarm. Is it possible to activate an audible signal when unlocking/locking the car ? I guess it will be the horn ? What is the coding to do in this case ?
3. I would also like to activate the anti-theft alarm (with the horn ?) if someone tries to reach in to open a door using the interior handle ? I prefer to go through long coding, but I haven't found the coding to do.
4. Finally, I have Travel Assist. Is it possible to increase the time before putting your hands on the steering wheel, which is currently 10 seconds ?
Aug 3, 2024
Thanks a lot for your answer !
Regarding points 2. and 3., do you know the exact coding to do ?
I would also like to know if it is possible to add automatic aid to the change of track, to exceed on the highway for example ?
Thanks in advance
bells0
19
Leeds/Bradford
I have this Vee Peak scanner from my previous Mini Cooper that I used to makes some changes. Is there any VAG/Leon software I can use it with?? Like to change the rear bar to be on all the time like I did with my Mini Union Jacks LEDs
Aug 3, 2024
Thanks. If I understand correctly, the camera firmware must be higher than 3400 ? Where and how can I check the firmware ? Sorry, I'm a complete beginner.
Otherwise, how to do the coding to have the audible signal when locking / unlocking, and also the anti-theft alarm ?
amadeumir
20
Thanks man. With this setting do you get the warning every 10 seconds of put hand on steering wheel?: THIS ACTIVATES A SORT OF TRAVEL ASSIST. TO WORK, THE LANE ASSIST EARLY MUST ALSO BE CODED AND THE ACC MUST BE ACTIVE WITH THE SET SPEED. IT ALSO WORKS UNDER 60 KM/H.
cant code this part
- Select Adaptive Cruise control
- Select Long coding
- Select PACC Reaction to end of Traffic Jam
- Set to Regulator adaption with speed adaption
- Select PACC regulation on priority
- Set to Active
any ideas, 2020 first edition.
Hi, I'm Italian, I share with you what I discovered:
EMERGENCY BRAKE SYSTEM
- Select Module A5 (Driver Assistance)
- Select Long Coding
- Select Emengecy Assist
- Set To EA Variant 4
CUPRA VIEWER and CUPRA STYLE
1/ Adding new views to cockpit
- Cupra View on Leon FR
- Select Control unit 17
- Select Adaptation
- Select View Activation
- activate view 6/7/8 the others are useless
2/ Adding all view Cupra on display and infotaiment
- Select Control Unit 17
- Select Start Screen
- Select Version 2
- Select Lap counter
- Set to Yes
- Select Vehicle variant
- Set to Derivative 6 (this Cupra Sporturer)
- Set to Derivative 4 (this Cupra Hachback) - Select Multimedia 5F
- Select Car Bodystyle addition
- Set to 1
- Select Vehicle type power stage 2
- Set to Yes
- Select Adaptation
- Select Function configuration hmi
- Select skinning
- Set to 2
- Select HC Variant
- Set To Variant 1
- Set to Active
SCANDINAVIAN DRL
- Select Central Elettric 09
- Select Adaptation - Select Daytime running lights
- Select Tagfahrlicht-Dauerfahtlicht aktiviert zusaetzlich standlicht
- Set To Active
ONLY DSG - AUTOMATIC DOOR RELEASE WHEN THE P BUTTON IS PRESSED
- Select Adaptation - Select Zv Autolock
- Select automatic unlock nar
- Set to Active
DEACTIVATES ENGINE IGNITION WITH STEERING WHEEL MOVEMENT
- Select Module 44 (Sterring Assistance)
- Select Engine start through power steering
- Set To Not active
DEACTIVATES ENGINE IGNITION WITH VEHICLE MOVEMENT THAT BEFORE YOU. IF ACC IS ACTIVATED, THE MOTOR WILL RE-ACTIVATE DESPITE THIS SETTING
- Select Module 13 (Adaptive Cruise Control)
- Select Adaptation
- Select Expanded restart function
- Set To Off
ACTIVATE FOG LIGHTS WITH HIGH BEAM FLASHING
- Select Adaptation
- Select LEUCHTE 12 NL L B45
- Select Lichtfunktion D 12
- Set to Lichthupe
- Select Dimmwert DEF 12
- Set to 100
- Select LEUCHTE 13 NL R B5
- Set to Lichthupe
- Set to 100
ACTIVATE OEM ANTI THIEF ALARM WITH HORN AND DIRECTION INDICATORS
- Select Adaptation
- Select Diebstahlschutz Schnittstelle
- Select DWA verbaut
- Set to installed
- Select Diebstahlschutz.Modulsoftware
- Select Akustischer Alarm ueber Hupe
- Set to Active
- Select Anti.theft blinkers by inter.door handle activ.
- Set to On
- Select DWA campermode
- Set to Active
- Select Dynamic turn signal control
- Select Theft flashing
- Set to active
couldnt code this part on my 2020 first edition err0r 31, any ideas??
- Set to Active
thanks.
Aug 9, 2024
13
Is there a way to get the same dashboard display that Travel Assist gets without Travel Assist, where you can see the vehicles around you? I don't worry too much about functionality, it just looks great.
Good evening, it is possible to see this screen on the display without having the capacitive steering wheel, thanks
