OBD Modifications
KokDu
43
12
I believe VIM requires an additional security code that is generated specifically for you car, not really sure how that works. I haven't heard of anyone succesfully coding it without an app.
This is how it works for older VAG units, via VCDS:
Instructions:
  1. Select control module 5F in VAG-COM/VCDS
  2. Select "Advanced ID - 1A"
  3. Submit the value from the "Serial number" field in the form below. If there's more than one serial number, use the first one!
  4. Select "Security Access - 16"
  5. Enter the personal login-code provided below
  6. Press "Do It!". If you receive a "code not valid" message try the alternative code. If neither code works it's likely that your control module doesn't support VIM adaptation.
  7. Select "Adaptation - 10"
  8. Select channel 48
  9. Press read
  10. Set the value to 255
  11. Press test
  12. Press save
  13. Press "Done, Go Back", close the controller and quit the software
  14. Restart the MMI: Press and hold down the function keys 1 (SETUP), the control button 2 and the control key at the top right 3 simultaneously until the MMI system shuts down. Release keys -> MMI system reboots
I have generated the set of keys for my car , based on serial number (if required by obdeleven) . Just can't seem to find where Channel 48 is (no such option in the software).
But anyway will keep on looking and post back.
Code generator is found here : http://audienthusiasts.com/Articles_VIM.html
Automatic VIM Generator:
"After retrieving your Serial number enter it in the box below and click the "Generate" button. You will be presented with a primary (Code1) and secondary (Code 2) to use. Always start with Code 1."
Just paste the headunit serial number and it will generate 2 set of keys.
Widil
108
22
Hi guys,
I just got the OBD11 (Basic version not PRO) today and tried to make some modifications but some of them didn't succeed. I am trying to put the 30 ambient color and it keeps failing. I already have the original with 8 to chose from but when trying to put the 30 it fails. Is there anything else i can try?
Sorry, I won’t have an answer for you but how did make to try to have more colors ? I’m really interested in that and I could see if I can way to make it work if I knew where to start
mulaganesh
38
12
To anyone looking to activate full link/ mirror link. My local retrofitter says it's not possible to aquire keys to do it anymore, because seat is looking into selling this function themselves in near future. We must brace ourselves with patience and hope it's gonna be sooner than later.
davidgballester
31
So now with SFD unlocked, do you guys think it will be possible to remove the warning every 10 seconds of puting hands on steering wheel when setting lane assist to early?
simoammi
26
19
Hi, I'm Italian, I share with you what I discovered:
EMERGENCY BRAKE SYSTEM
- Select Module A5 (Driver Assistance)
- Select Long Coding
- Select Emengecy Assist
- Set To EA Variant 4
CUPRA VIEWER and CUPRA STYLE
1/ Adding new views to cockpit
- Cupra View on Leon FR
- Select Control unit 17
- Select Adaptation
- Select View Activation
- activate view 6/7/8 the others are useless
2/ Adding all view Cupra on display and infotaiment
- Select Control Unit 17
- Select Start Screen
- Select Version 2
- Select Lap counter
- Set to Yes
- Select Vehicle variant
- Set to Derivative 6 (this Cupra Sporturer)
- Set to Derivative 4 (this Cupra Hachback) - Select Multimedia 5F
- Select Long coding
- Select Car Bodystyle addition
- Set to 1
- Select Vehicle type power stage 2
- Set to Yes
- Select Adaptation
- Select Function configuration hmi
- Select skinning
- Set to 2
THIS ACTIVATES A SORT OF TRAVEL ASSIST. TO WORK, THE LANE ASSIST EARLY MUST ALSO BE CODED AND THE ACC MUST BE ACTIVE WITH THE SET SPEED. IT ALSO WORKS UNDER 60 KM/H.
- Select HC Variant
- Set To Variant 1
- Select Adaptive Cruise control
- Select PACC Reaction to end of Traffic Jam
- Set to Regulator adaption with speed adaption
- Select PACC regulation on priority
- Set to Active
SCANDINAVIAN DRL
- Select Central Elettric 09
- Select Adaptation - Select Daytime running lights
- Select Tagfahrlicht-Dauerfahtlicht aktiviert zusaetzlich standlicht
- Set To Active
ONLY DSG - AUTOMATIC DOOR RELEASE WHEN THE P BUTTON IS PRESSED
- Select Adaptation - Select Zv Autolock
- Select automatic unlock nar
- Set to Active
DEACTIVATES ENGINE IGNITION WITH STEERING WHEEL MOVEMENT
- Select Module 44 (Sterring Assistance)
- Select Engine start through power steering
- Set To Not active
DEACTIVATES ENGINE IGNITION WITH VEHICLE MOVEMENT THAT BEFORE YOU. IF ACC IS ACTIVATED, THE MOTOR WILL RE-ACTIVATE DESPITE THIS SETTING
- Select Module 13 (Adaptive Cruise Control)
- Select Adaptation
- Select Expanded restart function
- Set To Off
ACTIVATE FOG LIGHTS WITH HIGH BEAM FLASHING
- Select Adaptation
- Select LEUCHTE 12 NL L B45
- Select Lichtfunktion D 12
- Set to Lichthupe
- Select Dimmwert DEF 12
- Set to 100
- Select LEUCHTE 13 NL R B5
- Set to Lichthupe
- Set to 100
ACTIVATE OEM ANTI THIEF ALARM WITH HORN AND DIRECTION INDICATORS
- Select Adaptation
- Select Diebstahlschutz Schnittstelle
- Select DWA verbaut
- Set to installed
- Select Diebstahlschutz.Modulsoftware
- Select Akustischer Alarm ueber Hupe
- Set to Active
- Select Anti.theft blinkers by inter.door handle activ.
- Set to On
- Select DWA campermode
- Set to Active
- Select Dynamic turn signal control
- Select Theft flashing
- Set to active
Reactions: whocarez and KokDu
davidgballester
31
- Select Adaptation
- Select Version 2
- Set to Yes
- Set to 1
- Set to Yes
- Select Adaptation
- Select skinning
- Set to 2
- Select HC Variant
- Set To Variant 1
- Set to Active
SCANDINAVIAN DRL
- Set To Active
- Set to Active
- Set To Not active
- Select Adaptation
- Set To Off
- Select Adaptation
- Set to Lichthupe
- Set to 100
- Set to Lichthupe
- Set to 100
- Select Adaptation
- Set to installed
- Set to Active
- Set to On
- Set to Active
- Set to active
Thanks man. With this setting do you get the warning every 10 seconds of put hand on steering wheel?: THIS ACTIVATES A SORT OF TRAVEL ASSIST. TO WORK, THE LANE ASSIST EARLY MUST ALSO BE CODED AND THE ACC MUST BE ACTIVE WITH THE SET SPEED. IT ALSO WORKS UNDER 60 KM/H.
simoammi
26
19
yes I can't find a way to extend this time, but I'm not giving up. If you make the road with many curves every day it is comfortable, if you make many straight roads it is a bit of a pain. but i keep it saved my ass for distractions :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
mulaganesh
38
12
Have anyone tried coding coming home/leaving home lights? I don't have it and really want it as my driveway is extremely dark in the morning/evening.
simoammi
26
19
Hi, here you can see a video: https://youtube.com/shorts/nZ7TmGoBGVo?feature=share
in the hairpin bends it does not work so well, and sometimes it jumps in the middle of the curve, hands on the wheel must be kept
Tell
They all have that for front assist. TA seems to be the fantasy thing use to be ACC a few years back. The boy racer thing to lock onto the car in front so as to get really close and get stone chips ;).... then all that involves to get the camera re glued back on with calibration if you have lane assist... then the threads this car is prone to stone chips :).
Having a DSG is helpful + lane assist ;).
KokDu
43
12
Video in motion is available as One Click app as of today, 100 credits. :)
Will test it tomorrow as I have some issues with my Obdeleven account.
P.S. there is a promo 200 credits for 15 EUR and 1000 credits for 35 EUR with obd eleven, Cyber Monday . I would say it is a good deal.
KokDu
43
12
:drive1:
