Trade up get a Cupra R.... Solves all issuesIf mine come back up I would
Think I found the cause gearbox issue I have been having. When still it would go into first fine but if moving then it would resist going into first on the first attempt but release pressure and push again it would go into first ok. On the top where the arms attach to the gearbox i noticed some shiney scrape marks. Went to move the arm and it was extremely wobbly with the arm scraping on the gearbox need to test tonight and get a socket on it but finger tightened it to stop the arm scraping. You can see where its cut the sticker in half and made shiney metal.
finally got my hb4 spot bulbs installed
just need to get number plate lights that work and h1 bulbs that fit, the ones i got where to thick for the hole
I know there are other options but these worked just fine for me and are v bright.
https://forums.seatcupra.net/index....ur-mk2-do-today.323748/page-1015#post-4782838
What's the difference between the gfb diverter and the standard revision g??Installed a new diverter valve made by GFB and also installed a new short shifter from forge sport
Thanks mateThe main thing is that it sharper throttle response and faster boost recovery when changing gears.
https://www.gfb.com.au/products/blo...suits-late-model-vag-euro-applications-detail
^ if you want to see all the things it does
Thanks mate
Did you have as much fun as I have getting the engine cover off lolFitted a k&n panel filter
So now I've had, cam chain and tensioner done. Cambelt and water pump replaced. Inlet valves walnut blasted and injectors cleaned. New oil pick up. Full service. Helix clutch kit and braided clutch line. All done over the last 3 months. Getting ready for tte480
