What did you and your MK2 do today?
ZiggyEP3
406
72
UK
Think I found the cause gearbox issue I have been having. When still it would go into first fine but if moving then it would resist going into first on the first attempt but release pressure and push again it would go into first ok. On the top where the arms attach to the gearbox i noticed some shiney scrape marks. Went to move the arm and it was extremely wobbly with the arm scraping on the gearbox need to test tonight and get a socket on it but finger tightened it to stop the arm scraping. You can see where its cut the sticker in half and made shiney metal.
Nut has come loose again so tightened the nut and will put some threadlock on it tomorrow.
stephen
82
10
finally got my hb4 spot bulbs installed
just need to get number plate lights that work and h1 bulbs that fit, the ones i got where to thick for the hole
saveoursouls
415
234
37
Manchester
Blocked the EGR vacuum, engine seems more responsive but that could be a placebo. Noticed oil spray coming out of the EGR but not sure if that’s new or not.
JohnnyMackers
31
17
Not much today, installed full interior white led lights and side lights..
I was planning on cleaning up a 8 month old miltek cat back, downpipe and an oversize induction so its ready for install but didn't get round to it.
Reactions: Brimfull
stephen
82
10
Just wh n lights are back up. I changed most of my lights over the last while as I posted here
My side lights are more yellow tone than orange
Is that legal? Just looks strange to me
Brimfull
1,385
418
Wrexham
No it's been off a few times since I have had the car, must say it's a crap design to have the filter in the engine cover.
However I do see the need for a cover as the 2.0 tfsi engine is one ugly looking engine
RnPnJ
110
So now I've had, cam chain and tensioner done. Cambelt and water pump replaced. Inlet valves walnut blasted and injectors cleaned. New oil pick up. Full service. Helix clutch kit and braided clutch line. All done over the last 3 months. Getting ready for tte480
Legojon
I only wanted a remap
5,311
2,741
Ace. What power you running at the moment? What you going to do handling wise for putting down the power? I'm ordering a wavetrac when the garage open in an hour.
