Big Brake Kit cont..
Well all the parts have arrived. I am waiting till next month now to get MOT, Brakes and service done at the same time. Hopefully that will save me some money overall.
As you can see from pictures below the calliper is quite big. It is a bit longer it looks like than the LCR Brembo calliper, the pots also look bigger too when looking inside. Hopefully this will translate into a better braking system than the Brembo kit. I should think so too as they retail for £1400!
The discs are 326x30mm. They are heavy but not as heavy as my current ATE discs are. Maybe its because they are two piece? Hopefully I should have enough clearance with the LCR wheels. If not then a small spacer should do the trick.
