Good morning. Can someone test if it works? It works on a Skoda mib 3, thanks
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
MartiniB did it on the Briskoda forum which is British. He found the SK designator and posted how to do it for Skoda owners, updated that twice now, BUT doesn’t work work for Seat / Cupra. It's a metafile steering command. Vag have always used them on their units but now they are software signed so you can't tinker with them. Some guys say you can but they clearly don't understand encryption. Programmers as well.Do someone contacted Phonestar about? It seems Skoda guys from UK forum did it and got it.
Enviado desde mi 2312DRA50G mediante Tapatalk
If it's got SE in this file you stand a good chance if not it won't work:OK, test it myself next week. It is a new version. That is why I will tried
www.briskoda.net
Conceivable their might be internal logo Vag files on the dealer network that have SE in them. What it means if they don't is the online release on Seat's is behind the other one.OK, currently no SE in the meta from me, but why not use my contacts ?
I have Version 54
It took around 40 minutes maybe, door openAnyone is that normal. Mib2 it's retained in the units memory. But other than that good news. How long did it take.
Well in my case I had the change to leave the car with open door while working, private park (gate closed) so all went okI thought door open would do the trick. When I lived in London I couldn't keep the door open and walk away. It was a trick a retrofitter used on a service station car park when they updated the mib2 firmware and I'd been attempting to hack the map file previously. They kept the door open with a box of tricks plugged into the back of the unit, laptop on their lap, 4g aerial on the dash. On the bench but in the car. I stuck with the SWDL method since you can see the update progressing. Good experience.
No private locked car park or garage you have to do 3x15 minute locked sequences, so you have 5 minutes spare within the 20 minutes before power down. Mib2 high I normally kick it off, come in, back out 15 minutes late... 5 minutes to get the shoes on and walk out etc.Well in my case I had the change to leave the car with open door while working, private park (gate closed) so all went ok![]()
Will pass on the question but if you did a factory reset before the map update that will be why the destination and home vanished.Something strange happened and just noticed after driving a while.
I did a factory reset on the infotainment system and updated my maps but now the sound of the parking sensors are not coming from the sound system anymore and I noticed that the heating on AC is messed up, pressing the glass area to turn that area on/off turns the other ones on/off and the oposite too.
Did anyone had this issues on their Leon ?
