Updating the inbuilt Mib3 Satnav Offline
Tell
Well if it's the Skoda file for that we know it doesn't unless there is a new release with SE designator in it.
I pinned a thread I thought was going somewhere but unpinned it when it wasn't:
Hinges round this
But Phonestar don't put the SE ID in it. They did once. So you can check each release. Wasn't in the last one MartiniBs post. I looked.
The missing SE:
All the files are locked down by signature encryption so you can't edit them unless you got GCHQ / NSA type of hardware or Vag accidentally publish the primary key. They would hang and quarter someone who did that.
cairus
806
249
Original for VW, but successfully used on Skoda. Completely legal origin. I wouldn't endanger anyone.
Nov 18, 2021
73
18
Do someone contacted Phonestar about? It seems Skoda guys from UK forum did it and got it.
Enviado desde mi 2312DRA50G mediante Tapatalk
Tell
But what is it thou. Radio logos ?. Since we know that isn't supported in the Phonestar files produced for VW but have been found to have the Skoda ID in them, but missing Seat. That one is across European Seat boards. On that the Seat sub brand hasn't made enough fuss to get the offline logo support implemented. I can see some dealer file could be coming put of channels but basically they want you to buy connect services. So updated logos aren't in the online upload managed Phonostar under contract and you can't upload the VW file since it's signed with Seat / Cupra ID missing so does nothing, works on Skodas thou.
Tell
MartiniB did it on the Briskoda forum which is British. He found the SK designator and posted how to do it for Skoda owners, updated that twice now, BUT doesn’t work work for Seat / Cupra. It's a metafile steering command. Vag have always used them on their units but now they are software signed so you can't tinker with them. Some guys say you can but they clearly don't understand encryption. Programmers as well.
I did suggest editting those SKs to SEs. People tried, thought it wouldn't work. It's on the thread linked above. Basically why VAG took down POI import to stop programmers interfacing with the unit through the USB. Logo import was never encrypted in mib2 but on that same token why it was taken down out of the spec. The disappearance of mibsolution.one is probably likely to be related to a contract that Vag had with a company to take down their server contract. It happened once before. Why firmware isn't being sold I guess by companies will be down to Vag wanting control of that through dealer networks.
In the meantime we have map updates offline, no issue with them. No radio logo import offline - no solution for Seat / Cupra. Mibsolution.one offline so no firmware by the back door via that site. Suspect something will turn up on that. The firmware is distributed by Vag systems so that's just a question.
If you want the Seat / Cupra radio logos via Phonostar then you have to hassle the customer support network to get VAG to commission Phonostar for the work to be done. British commercial stations are missing from the online one. Really no great surprise that a German Internet radio provider isn't on top of stations that don't broadcast in German. Vags failure in their contract with them, the quality of the logo product outside German speakers and not supporting Seat / Cupra. Good idea but not well executed.
Tell
OK, test it myself next week. It is a new version. That is why I will tried
If it's got SE in this file you stand a good chance if not it won't work:
MartiniB latest post which I'd checked so if you have anything later:
I checked that.
cairus
806
249
OK, currently no SE in the meta from me, but why not use my contacts 😁
I have Version 54
