mc funbot
The correct way to do an N249 bypass the full guide
nathan_20vt
365
Kings Lynn, Norfolk
b3nm33
213
After reading this I've been looking at doing the sai removal 2, I came a cross this on eBay does any 1 know if its ok 161200852906 eBay item number. Thanks b
Sent from my GT-I9505 using Tapatalk
mc funbot
its a beast its got boost
Jan 29, 2010
1,473
sunny kettering
www.seatcupra.net
Catch cans are good BUT 1.8t rely on breather ive know of problems with 15mm ports as the crank pressure changes. My brother machined myn out an made then 19mm so its all as it should me. I need to make guide but I dont have a car to do it on. UNLESS. Someone wants to drive to northampton an let me do it?? Whos game?
b3nm33
213
I'm game mate what would I need to get and how long would it take to do it.
mc funbot
Jan 29, 2010
1,473
sunny kettering
www.seatcupra.net
I can do it in an afternoon pal. You would just need your car I can make you a plate up and remove all the other bits.how far away are you from me?
19mm pipes on 15mm ports is ok just doesnt breath well. Increase in crank pressure an can cause oil to leak
b3nm33
213
I'm about 45 mins from you mate so not that far. I'm free any time to as I've just been laid off lol.
b3nm33
213
Hahaha yer sounds good mate it needs a good going over as it was a bit of a nail when I got her. Spent a small furtune on it all ready, seems like as I fix 1 thing some thing else gos lol. Need to find this leak though as it stutters like f**k when I floor it at around 3000 rpm.
b3nm33
213
I've done the n249 bypass replaced most of the breather hoses had a new cts and still I get it, there is a code that comes up pressure drop between Turbo and throttle valve. Any help with this would be ace :)
Longy82
372
West yorkshire
Same here but I don't get a splutter I've rather got full boost or limp mode when it brings that code up till I turn it off and back on again but we think its my dv that's the problem
b3nm33
213
I thought it was my dv but I replaced that with a forge splitter r and it still happens. Mine does go in limp mode ocasionaly to.
Longy82
372
West yorkshire
That's what I got and they apparently a bag of poo on these engines so just going to try a stock one and take it from there as when I adjust it it goes into limp mode quicker then adjust it back and still goes in limp but after about 20 mins or so.i just carnt win wiv this dv so hopfully this is whats my problem as I have no leaks at all.
b3nm33
213
Can't you adjust them so there fully closed though, and I've talked to a few people that say theyve had no problems at all with them. Need to find out how to test my standard dv see if that was f**ked
b3nm33
213
My o2 sensor light is on to as I have a Dec cat on it but don't think that's the problem.
Longy82
372
West yorkshire
Don't think so mc funbot has been giving me some great advice on what to do and try and not to try so just going to try a stock one and see what happens so see if I can get rid ov the codes 17705/16795
b3nm33
213
What's he said to try mate need to get rid of this asap. I have the first code you listed.
