mc funbot
The correct way to do an N249 bypass the full guide
Longy82
372
West yorkshire
Milks brilliant lol right just been outside again wiv my car and after looking a lot closer there is a split in the pipe you told me about the one under the inlet the one right next to the dip stick on the right. How do I replace it can I just use any pipe or does it have to be like for like?
b3nm33
213
You can block that hose then mc and remove it totally? What else can you remove from the beather system. ?
Longy82
372
West yorkshire
Right 007p on and the noise is like a little sneeze is that right? Does the plunger bit go to the turbo side and other end into the air intake pipe?
b3nm33
213
I removed that pipe tonight, off the mani also removed that plastic y pipe the t valve.
b3nm33
213
Yer ok will do, people are saying I might have a cracked turbo as my car stutters between 3-4k
b3nm33
213
Not sure if it's just me but there's no pic :-/
