mc funbot
The correct way to do an N249 bypass the full guide
mc funbot
its a beast its got boost
Jan 29, 2010
1,473
sunny kettering
www.seatcupra.net
Pictures would help no end :) the link you posted is 1 way of doing it but it dont really gain anything its just moving pipes. FPR goes to the inlet mani 1 direct feed then dv to mani 1 direct feed if you want to install a boost gauge T in to the fPR vac will give you a good reading.
The other pipes you leave open on the side of the head if your not sure blow down then an find where the air comes out that way you no nothing is using it if that makes sence.
hope that helps
Longy82
372
West yorkshire
And there u go saved me going out in the cold :) lol think u should move to west Yorkshire and be my neighbour haha still haven't got another DV yet but the more I play around with it it takes more time before going into limp mode. What I fully close it up would that stop it leaking if it is that?
leegreenaway
505
Merthyr Tydfil, South Wales
hope that helps
I'll show you what I've got when I get home lol, at the moment it's setup like the link i posted earlier.
Blocked off pipes only at the moment (until I remove them) then...
DV to the nipple on the underside of the inlet manifold, T piece in line with it for the FPR
You mentioned a boost gauge, I run a boost gauge with another T piece in this setup as well....pictures will reveal all later hopefully :D
mc funbot
Jan 29, 2010
1,473
sunny kettering
www.seatcupra.net
You wouldnt believe how many people drive to me for work. 1.8t stuff is all I tinker and build. Get a dv on and it should be ok. Ebay is the way forward mate. And you will have BOOOOOOST
Yes ill have a look at the pics an go from there.
Longy82
372
West yorkshire
I've just noticed that at low speeds and if I press the throttle peddle very very lightly you can feel the car holding back like its about to stall but put your foot down a bit more then it clears does that sound like a dv leaking at very low revs?
rallychief
101
I live in South Devon
Yep I have this slight hesitation below 2000 rpm, it is better since n249 bypass, any way can someone throw up some pics of where and how the standard dv fits, went to replace the e.bay thing that's on it, but now I have a standard one, I can see the one on it is totally different, it sits free floating in the air just behind and above rear of engine, it has a silicone hose coming out of the left standard DV size going to a metal pipe to left rear of engine, then a smaller pipe, going to somewhere behind PCV valve ( N75 Valve ), then a smaller hose again ( 4mm ) going from a spill on the top of DV which bypasses N249, their is what looks like a place for a hose, just after the airbox, on the outlet pipe from airbox, which has a bung in it, I assume this is where the standard DV or forge 007 etc goes to.
Help !!!!!!
Cheers Chris
leegreenaway
505
okay here we go...
N249 bypass based on previous link with T piece between FPR, DV & Inlet Mani
T piece in place near DV for boost gauge
You guide suggests just one pipe from DV to the Mani, where does the FPR connect to then?
Sent from my HTC One X+ using Tapatalk
mc funbot
Jan 29, 2010
1,473
sunny kettering
www.seatcupra.net
Ive just read that guid its a half ass one of myn. Just copy my guide. You have already removed black box. Just follow what I have done and you will be fine mate. You can leave the T in the dv line for the boost gauge of you like.
Charlie20v
30
Derby
I read somewhere that you get most accurate reading for boost gauge of the nipple on top of the throttle body. I tried it but got a weird clicking noise coming through my boost gauge so swapped it back
Longy82
372
West yorkshire
Right after getting my car back off my lass as she's been driving it all week another thing as come up witch she didn't tell me. When driving in any gear and let off the throttle so it's using the engine to slow down there's a scraping noise but dip the clutch it goes away or put your foot on the accelerator and it goes away just when you let off the throttle in gear if its ticking over clutch in or out no noise as I thought that could be the release bearing?
Charlie20v
30
Derby
this might be worth a read: http://forums.vwvortex.com/showthre...tch-disengagement-issues-mainshaft-axial-play
SWANSWAY CUPRA Dealership
