The next step - update #3
AmD have come back to me and stated that there BTCC engine guy can get the head blueprinted, polished etc...We are looking into options for the exhaust valves.
My american contact said he does have exhaust valves suitable for my application so will explore this possibility further. He also said he can provide me with cam and rods if I so choose. As I stated previously not sure whether doing the rods is worthwhile for me as I plan to keep same turbo.
For you techies out there: I gather with larger sourced exhaust valves all that is then require is to port out the ports bigger to match? Also I gather once the head is off and new head, cam etc is going in swapping the rods at same time is no big deal???
Rods are bolted up from the bottom, this will require the sump to be removed to gain access.
Interesting read :- http://www.speedtalk.com/forum/viewtopic.php?t=1692
Save up for a new turbo Maz, I feel after reading that link posted above, my suspicions are correct, the ECU will ask for too much boost from the turbo even at half throttle. Also talk of keeping the swirl and just refining it and only radiusing the entry ramp for the chamber should be enough. As we spoke before, the swirl is there to help the burn, less burn means more smoke, more swirl means less airflow/power. So if you can make the swirl work faster and smoother with a larger amount of air, you will keep the clean burn and raise the power. So porting to larger volume space, larger exhaust valves and keeping the ramp and smoothing/enlarging the head swirls should do it. Along with cam changes it should collectively raise the figures without too much smoke, which is what most cars do trying to hit big figures.
Once the head is off swapping the rods shouldn't be a big deal mate. But if your doing all this work I'd look at a bigger turbo![]()
Thanks Lee. I am not rushing it - trying to soak up as much information as possible. I think it will take until Mid summer for everything to be completed but the wait will be worth it. No idea what power she will get but a "genuine" 250-260bhp would be more than enough for a very quick deisel that handles.All I can say is that you've got balls of steel Maz and have massive respect for you for going this far to date.
Will of course continue to follow the story and hope that you don't get too much heartache with the progress in the mean time.
Thank you!great thread mate! and even better car!! probly never happen but would love to see this car in the flesh one day
Cheers for info chapsyip, part of the short block
Lets hope there isnt too many tears!
looks like its pushing your luck to me fella, but then mine is not exactly a "trained eye"!
Your welcome mate, sorry couldnt give you more of a demo.Thanks for taking me out in it yesterday as well as all the advice. I'm very much in love with your car.![]()
