flip key info thread
JPS3290
Dirty Diesel
Jun 6, 2003
438
Durham
I got hold of a 3 button flip key cheaply. Just transferred the transponder from the old spare key, reprogrammed it and working fine. As expected the boot release doesn't do anything but not bothered.
Just need to get the Seat badge now.
Fallen Angel
Leon Cupra 1.8T 20v 180
Well i got my VW 2 Button flip key (HL0 1J0 959 753 N) last week & got it cut at the weekend :D
However, i've tried using the instructions that came with it, and the instructions in the Seat Manual, it will not synch with the car [:@]
Here are the instructions i've tried:
* Insert key in ignition and turn on and leave in ignition
* Mechanically locl the vehicle using the drivers door using a second key
*Using the remote control press the unlock button once, and the horn will sound once (i got to this point, horn did not sound)
* Wait 6 seconds and press the ulock button nce t activate the coding procedure. The remote control will now be programmed.
*Remove key from ignition and check for operation
Or:
*Insert the key into the driver door lock, turn and hold to left position, windows will come down, turn and hold to right position, windows went up
Or Seat Manual:
* Both vehicle keys, the key with the radio transmitter (A) amd the conventional key (B) - i don't have B hence why i bought a second remote key.
* The synchronisation process must be completed within 30 seconds
* Use key (B) to switch ignition on and key (A) to program
* Make sure that the vehicle is open before you proceed to the programmming
* Place key (B) in the ignition and switch on
* Use key (A) to lock the drivers door
* Now unlock and lock manually the drivers door with key (A) while pressing the open button
* Take key (B) out of the ignition
PLEASE HELP AS NONE OF THE ABOVE HAS WORKED, WHEN MY NEW KEY, WITH NEW TRANSPONDER IS IN IGNTION WHILST DOING ANY OF THE ABOVE, THE KEY LIGHT ON THE DASH COMES UP AND FLASHES.
JPS3290
Dirty Diesel
Jun 6, 2003
438
Durham
Put your original key in the ignition and turn it on.
With your new flip keep lock the car and remove key from the lock.
Press the unlock once, horn beeps, count to 6 and press unlock once more.
Remove original key from ignition: Job done!
Fallen Angel
AS i've already had the blade cut, can i keep the right hand peice and sell the other and buy the correct remote section do you think?
ViolatorDM
The transponder is fitted into the right part of the key and the "chip" is fitted into the left part of the key, so, I think so yes...
