flip key info thread
viperrr
52
Midlands, nr Telford
Gah, badge number?
Hey guys,
I've had a trawl through here since page 26 or wherever, and it's mentioned that the part number for the wee seat badge is 1M0 837 891A
I e-mailed a dealer about this, and he tells me it's the wrong part number. He also mentioned that it looks like the badges come as part of the fob.
Can anyone shed any light on this?
Chemical Al
Trollied Member
Apr 6, 2004
2,043
Craven Arms, Shropshire
Hey guys,
what dealer was that?
deffo the right part no. they are about £3 + vat
and its a leon mk1 part no. i think i saw it (www.vagcat.com)
Jamjarjames
so can anyone shed some light why my 434mhz flip key won't work on my 05 Ibiza Cupra, is it anything that can be solved in VAG com?
viperrr
52
It was Seat Crewe I believe, I got the e-mail address from the forum section here. I have tried e-mailing them again with the extra letters on the end, and I'll give my local dealer a shot when I call them later
edit: OUCH! My local dealer has quoted £90+ VAT to re-program my immobiliser!! I think I might just buy a vagtacho cable instead
Jamjarjames
already checked the battery, ive just been to a VAG electrical guy and he said you need VAGCOM to code it
Chemical Al
Trollied Member
Apr 6, 2004
2,043
when you say it wont work, what exactly do you mean? if its the remote part then this can be coded using the methods explained in this thread, OR using vag com.
if it is for the immobiliser then you need to get this coded either with special equipment or vag com providing you have your SKC
Jamjarjames
its the remote part, ive swapped the transponder over from the old key and it starts the car fine.
Intrestingly if i put the new key in the ignition and then code the orginal key the horn beeps as it should, but the new key does nothing
Chemical Al
Trollied Member
Apr 6, 2004
2,043
your in luck!!!
Remote Control Erasing
1. Switch ignition ON and leave the key in ignition.
2. Mechanically lock the vehicle using the drivers door using a second key.
3. Press the remote control unlock button 5 times in 1 second intervals. A short horn will sound.
4. Wait 6 seconds and press the unlock button once to activate memory erase.
5. Switch ignition off, all remotes are now erased.
Jamjarjames
that won't work either, it just beeps the horn after one press to tell me its coded the key?
Gernster
nah, not turned up yet, emailed seller and hes says it should be with me monday
bjc_uk
Ok, first off just wanted to say hi as i'm a new Leon owner after upgrading from my 1994 Ibiza this week!
Anyway, picked up my 02 leon 1.8se and it hasnt got a remote controlled key. Jus the normal imobiliser encoded transponder key!
My question is this - Will coding flip keys to unlock the doors by button press only work if the car originally had a remote control key? Perhaps a stupid question but gotta admit im a noob!!
Great site guys!!
Ben
viperrr
52
Great site guys!!
Ben
Hi Ben
I'm pretty sure your car should have a remote locking keyfob somewhere.. the 1.8 SE is a higher trim version than my 1.6S and I have one. It may have just been lost, but yes you should be able to get a remote key to work with your car
