Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Ah right so the only thing in the left bit/remote bit is the battery then? The immobiliser chip and transponder in the key blade bit? Im confoozed lol
Ok, then we're two people calling it tranponder/chip and both of us say it's all that's in that part of the key. Good.part that holds the key blade also has the tranponder/chip in it and nothing else.
Not the 2 button Audi key I tried it on.This part can be clipped onto either a 2 or 3 button remote (not sure if it will clip onto an audi one though)
Right so transponder is definately in the blade end, surely the immobiliser chip should be also??
I've a part of a key, like the right part in that pic, the part with the key blade in. I got it just because of the immobiliser chip, I needed a new one. The battery is in the part with buttons.
The only things I've worried my self with in this flip key process of mine, is getting a blank blade (easy), getting it cut (easy), getting a glass thingy (easy), match it to the car (easy), getting hold of the correct part with buttons on (hard), getting that to work with the remote lock/unlock (hard).
-snip- Used Transponders and Chips can DEFINATELY be recoded. -snip-
arrrrrrrrrrrrrrgggggggggggggghhhhhhhhhRight so transponder is definately in the blade end, surely the immobiliser chip should be also??
)Ok, then we're two people calling it tranponder/chip and both of us say it's all that's in that part of the key. Good.
So the two button remote thing that was the N version i can just buy the correct version (of which i have no idea) and it will work with the blade section i already have?
correct,
here are 3 that should deffo work
HLO 1JO 959 753 A is 433mhz 2 button
HLO 1JO 959 753 AG is 434mhz 2 button
HLO 1JO 959 753 AH is 433mhz 3 button (boot button will only work on mk4 ibiza on leon the button has no function)
