Originally posted by Glenn
The waters have been muddied somewhat by the Milltek D/P not actually being what it was supposed to be and by Bill's car requiring higher boost than the equivalent IHI'd Golf to obtain a given output which suggested that any restriction may not be due to the downpipe. However, it may be that even the IHI D/P on the Ibiza is more restrictive than the equivalent Golf version?
I think I said somewhere on here the MKIV outlet is going to be better flowing as there is more space... Rear engine mount is in the way on the Ibiza (which is MK2/3 Golf front end). tighter turbo outlet, but a packaging exercise as with all things Ibiza... Very small car for a 1.8T motor to reside in.
MKIV based cars can use Jabba's cast turbo utlet, which is larger and free'er flowing... runs into 3" downpipe also, vs 2.5" on Ibiza.. It is VERY tight under there... Engine mountings, movement are an issue... Driveshafts are mucho close to touching, and I have had to stiffen/replace my motor mounts to prevent the DP from hitting the top of the steering rack. It had to be heat wrapped to stop gaiters & engine mounts from melting...
10psi IHI boost produces over 250bhp and similar torque...
what will an E05 need to blow to achive the same (more torque tho)
E05 will run hotter to produce the same power levels, as its running higher boost to get there.
The Golf is an easier car for fitment... IMHO.
bill
