Boost is 21psi and holding 13.5-14 psi at the red line .Originally posted by ibizacupra
What boost? How did the induction temps fair?
238bhp and 259.3lbft torque
5th gear run perhaps to load it a bit more.... maybe... Usuallt 4th tho.![]()
bill
After 6 back to back runs induction was at worst 45 degrees ( No ice cubes used
5th was used to load it more and mike said higher figures would be seen using 4th gear run but by how much i dunno.
Before fitting, my EO5 was identical to my kkko3 in everyway except the size and blade profile of the impellar, and also wastegate actuator .
Eurocode said they use either kkko3s or kkko3 depending on what they get hold of at the time .
kkko3 is machined to size of kkk03s to suit impellar size.
Mike said E05 is basically the same as the kkko3s power wise ,only a few extra horses would be seen on eo5.
As seems to be the case
Just dont get it as to how the golf ( Mike ttish ) is getting so much more out of his EO5
