Diesel from a drum.....?
/dev/null
1,649
101
one question was this garage some back street dodgy guy??? or was it a big garage, i can safely say that if i bought diesel from a garage and my car stopped running i would take it back and get them to fix it
Exactly - I hope you have had strong words with them and asked them to at least contribute to some of the repair bills?
Andrewcupra TDI
Resident Desk Jockey
Apr 30, 2008
3,282
in the mountains ( Wales )
im waiting to hear from that angle,.
ive found a set local for £250
part finder found them for £350
guy who has my car wants £700 and if pump goes all in for £1000
think il opt for local set and get them fitted for approx £100 (2hrs labour)
what you reckon
nathibizafr
hi mate i had the same problem with my ibiza, i put a drum of diesel in and there must of been something in it, i got about 2 mins up the road and it died, i got it going again and went straight home it then died again, i took it to my work and drained all the fuel out of it and blew all the fuel lines out with a air line put some new clean fuel in bleed it up now it runs sweet as a nut i havent had any problems
if i was u i would do this urself because garages want a fortune
Andrewcupra TDI
Apr 30, 2008
3,282
Hi Nath
have done all that , (uncles a mechanic) and said hes seen nothing like it before,
have now given it to a derv specialist and sent my injectors away ,, and have come back as nackered , [:@]
so am now faced with the above post , am thinking get them local, from a reliable friend
and get the garage where its at now and get them to refit £100 ish isnt bad for refitting , as ive been told their a PITA to do :think:
Andrewcupra TDI
Apr 30, 2008
3,282
ok can people in the know help,
my injector numbers were read as 043 472 0039 (GSF said is incorrect and probably 0414 720 039)
my friends set are from a golf, with codes 0414 720 007 on them
are these compatible, with my engine , ringing around and no one can really help
cheers
andrew
Jan 22, 2007
2,074
some may say lala land....
is car ARL engine model as cupra tdi 150?
if i can etka working i'll have a gander - very useful tool to have in box
[edit]
read 1st post anot see it is arl
now trying to use etka and find your bits
[/edit]
[edit]
doing a search for inj and comes up with 7 hits, but none seem to give me the injectors for arl, but does for other
still looking
[/edit]
2,074
your fine with that you were given and i said.
etka gave me that and i think the link confirms the part number for you.
just shows the how injector pump broken down
i should have tidied up my posts so not to confuse.
What has a dealership said?
Jan 22, 2007
2,074
what was the full part number they gave you?
can see what etka says, but bear in mind the dealer will be able to say if the part offered has been superseeded by another which i won't be able to tell.
Andrewcupra TDI
Apr 30, 2008
3,282
Hi. The number off the injectors are 0414 720 039. The dealer said mine was 079 which suggests mine has the earlier injectors as listed above. Would anyone do then they guy at garage where my car is thought they were all the same ?
What about the people who uprated their nozzles have they/you kept same nozzle type
