Andrew, have you changed any o-rings on the injection components?
Heat = expansion
Dodgy fuel which is contaminated = not comaptible with o-rings?
Something maybe expanding slightly when hot, and a o-ring may be out of tolerance, the ECU may not be seeing the right pressure somewhere which is causing a no start.
Do our cars have a injection pressure regulator?
dont think so had new/used injectors off glynn
