Cupra - Black n Blue
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
small update, i spent a few hours playing with my nob
took it apart
then spent ages trying to split the plastic bits up
primed and ready for action
then started feeling a bit blue
light doesnt do it justice
neither does no light, its better in the flesh tho
and ordered some trainers to match :funk: (dam store dont have 11's in stock[:@])
Richy Cupra
Fully paid member
Jul 6, 2011
1,368
Essex
Looks good mate. I tried getting the ring round the gearknob off and chipped it by accident. Whats the safest way to do it?
RaviR50
2,756
Southampton
Get a small flatblade screwdriver under the little badge on the top and lift this off. There's a screw there holding the surround on (the bit I've painted). Unscrew it and the surround just lifts away, then simply spray and fit back together :) removing/re-fitting takes all of 2 minutes.
seems quite easy :)
RaviR50
2,756
Southampton
i just tried getting off the the badge thing with the number on but it didnt seem to wanna come off. I didnt want to jam the driver in there then rip out chunks, any best way of doing it??
Richy Cupra
Fully paid member
Jul 6, 2011
1,368
Essex
I ended up using a stanley blade and carefully lifted it off. Wrapped mine in carbon today :D
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
finally after over a month my car is in the repair center getting this fixed
and it gets worse, the hire car is a bluemotion golf :censored:[:@]:censored:,
my car goes faster in reverse
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
finally after a whole 30 days of just hanging out of the top i put my tax disc in the actual tax disc holder. bloody security screws on the back are a nightmare.
also tried and failed to fix my lose door blank, it looks like someone has taken a screwdriver to it to try and get it off while the car was being repaired the other week.
is this the torx screw that other posts say to tighten? because its as tight as it can be
the whole blank bit comes out easily when the handle is pulled
only difference i can see is the plastic clip is missing from one side (there should be a bit in the red circle the same as there is in the blue) but i cant se how that woule hold the whole thing in
any ideas how to fix it?
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
from various other threads
5/3/13
Took my car in for a service, mot, aircon service, replacement coil packs, both belts and waterpump.
Then i was told there is no point them doing the mot yet as its going to fail on a dodgy headlight bracket, damaged nsr spring, broken exhaust bracket and its going to cost over £900 to fix the steering rack,:scary: i never had any problems with the steering.
[:@]:censored:[:@]:censored:[:@]:censored:[:@]:censored:[:@]:censored:[:@]:censored::banghead::banghead2:banghead::banghead2:banghead::banghead2
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
took it to another garage for its MOT and its only going to cost me £35 to get the exhaust bracket welded back on, so woop woop no £900 steering rack needed from the stealers.
thank god for super glue holding the light bracket together.
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
got myself some show plates so my plate isnt show allover the net
just need to find a way to fix them on but so they can be removed easily
