Cupra - Black n Blue
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
Busy morning
Before
Peeling plastidip
Now :thumbup:
Now to eat some lunch then clean it.
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
did a bit more as its a bank holiday weekend
yesterday i started a little project
and i had some help from the GF
Did one more coat on the front this morning then moved on the the rear,
i think its ok to support the rear like this :shrug:
the rears were caked in years of dust
but nothing a dremel couldnt fix
then broke out my secret weapon, the GF
and had the rears done in no time
then noticed this pipe, couldn't think what it was at first, but now i think its the fuel overflow pipe from the drain port under the fuel flap
now i have to let them sit for 24 hours before i can drive the car [:@]:censored:
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
As it was my birthday on Monday the gf got me this
A seat trolly coin :clap:
I also painted my battery cover i got from eBay
But I haven't put it in the car yet.
And today I started my big boot build to get rid of my not so stealth sub box.
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
Started my 2nd attempt at a boot build a while ago now but its almost finished so i thought its time to update my RR
starts with a blank canvas
cut base wood to size
test the desired height
add some supporting wood and add some base material, it helps to have a sexy assistant
add some fiberglass matting and the wood for supporting the sub
add some resin and hardener
cut a hole for the connectors
add connectors and line the box with an old sheet to make it look snazzy then add the box lid
test fit sub
add a support ring for the top cover
add some feet to the support ring
test fit the top cover
stick the support ring to the top cover
FYI £19 gazebo is worth every penny
check it clears the sub
add some plasti dip
then add carpet to the top cover but don't take photos because you are covered in spray adhesive and install it in your boot.
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
To install a bad ass sub install in boot please follow these instructions
remove spare tyre, tools and all the crap that seems to accumulate in there
add sub box
add side plate
Add sub
fit amp and connect all wires as needed
insert top cover
have a cheeky test play of the LEDs
insert amp access panel
and finally insert sub cover disc
removal is reverse of installation
now to find a new sub without a big crack down it
(its not as rattly in person and the iPhone cant pick up the sound properly)
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
Just checked my insurance to make sure it won't go up by much if I put an exhaust on and woop woop, it's free to add it so I just ordered my new SSXVW052 cat back exhaust, the guys at awesome not only price matched they beat the price and it's delivery included all for £370. Now to find a place to fit it for me.
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
Oooohhhh I wonder what this could be
And my Gti international seatcupra.net show stand ticket arrived.
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
Yesterday I fitted my milltek non-resonated catback exhaust
Yes I painted the tips with the left over blue caliper paint, I'm starting a trend I know it.
Needs to somehow be adjusted a little bit
nathan_20vt
365
Kings Lynn, Norfolk
Loving the leon mate, looks asesome. I've got a yellow cupra and thinking of vinyl wrapping my bonnet matt black (dunno if it would look right) until I see this plastidip. Never seen it before. Just wondered how easy or hard is it to do and if theres loads of prepping to be done (never spayed before) looks like you've done a top job!
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
get a picture of the full arse end!
i will do, when its light out
i just cleaned it, dried it then sprayed it, pics are on the last page, its easy to do, it just takes time between coats.
Loving the sub build! looks cool
thanks, its got a new sub in it now but its a bit to loud and rattles now so its on my list of things to sort this weekend
nathan_20vt
365
Kings Lynn, Norfolk
Yea I see your pics that's what give me the idea. Did you use any primer atall or just straight onto metal? I've never sprayed anything before so I suppose it's a bonus being able to peel it off if it goes wrong. Is it easy to look after once done? Sorry for all the questions
