Going to build a race 1m
Manic172
Dec 4, 2018
1,403
1,501
Hemel hempstead
www.seatcupra.net
Mr postman bought me some more presents.... so on opening the box I was quite shocked I only ordered them the day befor
some carbonfibre roll cage protector..oooo isnt shiney ..and it's real carbon not plastic with painted squares hahahha
can you have too much carbon....
Manic172
Dec 4, 2018
1,403
1,501
Hemel hempstead
www.seatcupra.net
Today we tackled fitting a rear window..... a polycarbonate window that was flat not curved like the original.
Started of laying it place and making sure it fits. But at this point I realised that is was just clear.. no black out line.
So I drilled a 6mm pilot hole in each corner and in to the boot lid for line up
The ones in the boot lid I then drilled out to 10mm to take a 6mm nutsert. I know it seams to big .
But with the windscreen bonder and then pulling round in to a curve it will fit....🤞 test fit with the bolts in the corners holding it down
So holding the window in to position i then draw around the tail gate frame
. . So then I can black out the outer edge using the window primer , but first take of the protective sheet thats on both sides. But just tale of the side your going to bond too
To make it look like a normal window. Also run the primer on to the tailgate
Then run a bead of window bonder around the window frame edge on the tail gate. ( and forget to take any pictures )
I marked the top and bottom middles with white board marker on the body work and on the white protective sheet so I could place it straight in to position
Peel the corners back where the bolts go threw and lower in to position. Lining up the markers. And put am m6 bolts i each corner to help pull the flat sheet in to a curve
Personal touch when dryed i took the screws out and filed the holes with bonder and flatteren to make it look pretty
Not to bad considering I never fitted a window before.... youtube is your teacher hahaha
