ND-Photo.nl 's - Seat Leon ST Cupra 280
nd-photo.nl
4,206
352
The Netherlands
youtube.com
Performed spark plug change and went with Bosch OEM replacements. The spark plugs looked ok to me, but the 2 middle ones had some soot on them. After swapping them out, the engine feels just that little bit smoother. I used a very light coat of ceramic paste on the outside, to keep the coil boot from sticking.
Partnr: Bosch FQ5NPP332S 8160 Double Platinum
AP1GczN4pUYFkQXB-69ZEFjLCNyndRldUBIaORPOqHn2wrL5Rc5Y01-Vk3Z_v_NQ1duo3K7mCEsCi7UH7Fzcj2RMjjZir-2WH_0jz86OVUwLeZTt0dYtXgtgA-zJd3amjR1v095BaZcHIGzhhTtbbxcD-_RLIQ=w1920-h1080-s-no-gm
AP1GczNC5j0_V_Dxr9P56PwORwo0sI0pXylEXguOY30edzbiCNnBbmkfRfptalkAjTT6yN4c3qq2IpjkdGy6aSSI909GgM-_IqzTrqTAjLrUbqLER5bHNiU9Wz9ujuElA1_V6VqCTFLcb_fPjeZRXblxP5t2RQ=w1920-h1080-s-no-gm
AP1GczOc4XrWSJ7mC2WBC25_qOUcYDPUuZvsQJuFvou5_Cnv2K7SeHgp5q_EpHzQI8dc09LM5MHaxIKF9JZsrcR2CvZzz05YAVmKMDpU64hn2PJwG20Kq2yGqNOWcuQlpezjHqzoBxuGWkYvKIdQJrExN3awFw=w1920-h1080-s-no-gm
AP1GczPwM06BxgnRRAtQC8HLJTJLvP6S26Itw5p8t2AnS-jIAx85hvr8cHND3U8wQdA_5D1hnhKPoL3Bxs5wwLcAjroXGtik3AgAGurBUOZwjWSNoKiBdaWJ-VjkKIhsXz90Q1i_Z0UBWAJoCGSJdKN5Ag9Vsw=w1920-h1080-s-no-gm
New vs old
AP1GczOIjxXqme4twNKv2z1UIuopQhh3ATlFkz8Xt-FwkfOrgbNUJErXs3e6y8lSsMoMKSHeEaxwMJR8tij1FpCxhAIivIRQUNS_ZnsO4PKK3B7Famq57IqGLkJp2B3qliXzipyyDL9MIwRKqIKFeOL2QAGv2w=w1920-h1080-s-no-gm
AP1GczO39gadTbob7gNM1yNbqJ5UKaK3MDTzHZg3ZCYU2FPu3XPXca2Xb-vdDVTHCWZeK4KEuBE-IgxW3xmI_JjJF1gdggCArbOQYKVVZN-Jx1v9_AQ8G9Ng7Tfq4UlbNCQ0HoD-UqM2eApfu1vyPXSvSnfrXg=w1920-h1080-s-no-gm
The soot I mentioned
AP1GczNGBOHGc5uEcSJAJq7gp9Wy5QOHabpwIS9HT2QSaIsz_8QoB53iZbOg76ytLNVFT1Hj8qvRT4cd7Uqa5ISZaqMGVNVLdCpAy8Y8FVdG8YXyqI1Ltd30AkZlUs3qz-S2SrcLdNuKrRBwe5mhX6ZjS4z4NA=w1920-h1080-s-no-gm
AP1GczNzt3UZGWFt1XlGj41zS83Su3eSdzO7qpVw9oDnd2qkj1PCumxs43muLpizCX82JOn90UTUclt-UCZ-6D7J-ZIzG0uF3dcNSJrxi8BhuCXe7fVUduVM8_EaMqfJ7GZ1XVVFA6ilviPqsCctW2gfR_IjoQ=w1920-h1080-s-no-gm
mjj4
108
94
Just read through this, you've done so much already! Looks awesome. I like the standalone exhaust valve setup - even if you haven't managed to get a replacement unit yet (or sorted the constant vacuum pump running issue).
nd-photo.nl
4,206
352
The Netherlands
youtube.com
@mjj4 Much respect for going through my topic!
Unfortunately the standalone valve pump was a bust. I tried 2 pumps and both showed the same behaviour more or less. I decided to use the solenoid which was already on there, but not split from the brake booster hose.
I already did some more things in the meantime, and most of the things I documented with pictures and video. But video editing takes a lot of time (unfortunately). Stay tuned!
nd-photo.nl
4,206
352
The Netherlands
youtube.com
Replaced the dogbone with a new Lemforder dogbone. I didnt expect this to have a lot of impact, as the bushing is very small. But I was suprised as this makes the shifting almost feel seamless, wow :oops:
I also replaced all 3 bolts. Highly recommend if you have a 2015/2016 car, as this item will be around 10 years old.
AP1GczOsZSDGzdc8u0K6O7tFgcFYBorR4TZG5QXVoSKA38Q1DHQjgBbSUD2P1Fq1owQp4pfxrKjWWwEipKIo14vO-wyUS3uN9ym9UNWPq3xjEz-_ZnzcqnRdV89ES1OH_q31HZaMf9hOJ3wmPQv4YNIIYJkngA=w1560-h878-s-no-gm
AP1GczOZ2e3FUaQNG6D8bmBw38MmKNzN3zSAGSVLmn1E00zfYgmBt3bps3VxUgx0_9zZWcig2ZdDkGw7llE9ux5KQ27HN9ALglDpMKg3-bfWkBFX5mDWJa2E-zWQQWx7NPDkCMBTuOX2j7ifzG6QUlAdevGe4Q=w1560-h878-s-no-gm
AP1GczNCSlBSviH7_1rEefoF_aFgygsJzdm96IDleTkBP30CV7XRrJZOSsIQ4twKMzzCIX7UqBfutu6J2tkoV9hbnIh1z-aJ7WX_E7V4wGYFB7buvEa6vePjPVJpQEizcjeLHRqX7k5qYQpl3LTB0894nUX4fA=w1560-h878-s-no-gm
AP1GczOZGHUbp51c9H-3B_a1I4ey7fWy3M5Yip5ct9zFiVgosTqPlx5SZ_x1oRlJ3daejj62xf_-BxoyU0TuLE5fQxNt8rPB9exqRXq3MDQUKWU26Wl6AH8CJO7LZAf0XyaqI_gVo02YsUKEJQldGsCPCmfKhw=w1560-h878-s-no-gm
AP1GczOlewVr36bm86N_nUlgVFO1sCgNi7Dp03D_4gH_EVIXG6NQpeiBWHlfoYOu8LC6cHiP0uWKckTK4UH-Unv7iB2mg6V0jjwtGH5xgo3WYf6LO25KimBa6S2Lztkd1xGkJb68vaGHSiUXkgbiRUnS8jW5qA=w1560-h878-s-no-gm
Old vs new bolts
AP1GczP-H8NDoZaEIHzG_DLekzQye7DxhSiXEg-PYRtEBKm8oBsbwrXIFh6UeAbIUwqleX1yvX88AVSn3gmWhYeguLV5NC41nX2FvB1Xkdjp_FJXsYD_aTqAlahMsSRVqJteFlF_I3Or9UwaRCKJmNT3bFRzVA=w1560-h878-s-no-gm
Old vs new dogbone
AP1GczO7CGASOWJ01nm_9x09rFh2v14ivkvt-rocTiDUJV3xqEnIxKjzr1T_ydXxPu5KmloTA0ZwLwl3RY1DEyYRKqkKuF3WRALlKb6l_ZoenK5JIUYZP_yjpGkO45m5ji2kfnrg6al8LrWD8p9REMvm7dSl9Q=w1560-h878-s-no-gm
Production date 01-06-2015
AP1GczP6D8z6GWgh_NyHcLUEGix8nYf5pSlFfqjZuDEDMRY1ETQ4vbmMS21dwt2n5QyjbE55-PL77-JwoVmaxSWgxLak80wZRiyrcSw4Xt_rvjVtOoylLbB_DqbqunV0PYd9cmJtFIjRM5Ye5eMT-YJ1Zqbq3w=w1560-h878-s-no-gm
AP1GczMX3UkQKP17zVrHr4m6vgldX0o22AjJ5UdedFIjdPBC1JFbVCsXYVSMi5yXW2WHbfH93HQoMuMgkusawBPrYQdNcGLNu5rKhYGfSkwe73jLTNVLRDIQ0lnuRw62L-QahETi_X3fyNq5bcIf2kqkcVHqeg=w1560-h878-s-no-gm
Torque specs dogbone mount bolts
16mm: 50Nm + 90 degrees
21mm: 130Nm + 90 degrees
AP1GczP4UOldZ-MP7oIFHQN95Dfc0Dc6kNljIo65t2UT-KfbNhJ8LVllqy6jmg_4wscD9HOfWwGhIj-K1uO4n3vK_DWkN6DDHWWqk3ilYYYVIqMWLJ0sQn8IR9ctbA2dvNLvjpBbcHx5HlyNP0lkk9Euin-AKg=w1560-h878-s-no-gm
Reactions: csd_19
nd-photo.nl
4,206
352
The Netherlands
youtube.com
Seems I forgot to post this small modification. Even though I like the interior, I miss some dabs of color here and there. I added some red in the DSG shift knob. I like these small mods which add some flair (y)
Its impossible to remove the shift surrounds and keeping the locking tabs intact. They are fragile by design, so buy new ones whenever you need to remove them!
All ready to go in
AP1GczPTkR_Nq76Pj-U4waUritvgbkDz0SO28_7yllYO807jtnOO6cokSszjTxhd_iD7neS2Am5ONE5_Lp2GcVPxoAmlMvGnZ91Gln6DTVuTEZJGWQ7CIS8Kcx_2NCkVYG32l3RRrQpFyMj3DsdHCh0pG5bc0A=w1920-h1080-s-no-gm
The one I had mounted in the car. Looks quite chique, but lacks some spice ;)
AP1GczO9F_EXYdvrBNj9EtPpd4q4JnQ7Tia89b1QomgzuTuAsQ5jM5voc4V6Edpcs0q1bbUzydz0QmU6x0C-tKmQyB1mjBfrmVGFtyYL9Gf1lLPIblUr5fElq6W8IY9LBG6sKhuV-ZBabloUGOJXvH6TLe59MQ=w1920-h1080-s-no-gm
AP1GczO4c09i9k-vOOeRSL2OGmCB6Idq7yid4SmzMn43ta1BPXHhATj2QQbUXjaymYrMI4FOmjoHng8IbMaBku-KBbkF-j7r-HEqLD6vhQ1uVoS71nhS8Goq80yY3mTgu7DhajUQt4fy3J0tp8cWIFFuSegiPw=w1920-h1080-s-no-gm
Halfway done
AP1GczMm7I9Jja_K2U16jNdpk_qg6zvEaQpssyvOf07cozB7SHI5YkC8UMPHjxvm33X8H95Xy5nRxmi4df5ZlpjxHe_sX6_vEuW0FGXAZpikBDgZRiepssufP_-ltlHRG79X-lStdAwSeAb1Q7h1VXEb-Fx1tQ=w1920-h1080-s-no-gm
This is how the interior looks when you remove the surround. I also bought a new button and top surround, but I didnt replace them as they were identical (gloss black in my case)
AP1GczPZXJ5_uZtkVL0mpuX7rBkkIPFTB3aiD9SP7ZyVNh2Xb7K5KXbIcY6W6TfCoP3mXaGBrEENa7pknrXpszX3mZ-e5rTZrDM7q1OF9AqvWXIs7spkrEDnQIDFdXKKzvjZbxSeMeTa9L9DvT1tSDJDyFIXgQ=w1920-h1080-s-no-gm
Adding some more light to it
AP1GczP6KANkXixwi8U2p6dk7TkMoYWknDyIpbAhDQNN4xkzcktfb_CRxQQExIYLmOZBO54WL2t4jbrtyQWDVYgSWXhyJBX455UFSkFDGFIVrxKsYG54Rn5OKKPQio6qmCG5Ueji9Og6SVwcse5IM3g8vnHoUw=w1920-h1080-s-no-gm
AP1GczNTFUmVGLlRq5dS95gGS0T6OnRjVvUVaRZDAW1psQUGGClyoIccEaiabKljgx77V8CwK-WKeitTAf_x71Pi2P2dc7Qabzgr5JSMHVvCQcxNCWmM9Ux0NFnmgn_P6DmTyH-g3T_FOzBi3Kuh8CGLPxZewg=w1920-h1080-s-no-gm
AP1GczN2TxXbwjIP6IcZhuk6gGpDw7QL0SKHJ4v5u_C1VqE_q2CH-xN7spUIctShx_iXjIJEr61_McYVp62F5sg48ml7Wr3Wpq4u1E9BTWlgHcNez7kuW37P05hi3y8hohxzBT6Yf76wv5_XA1tSmPOJXDbGcQ=w1920-h1080-s-no-gm
All done, I'm very happy with the results
AP1GczPPqx6kexxSblynGFP3CVkHwaYd_A9UqFIWlB7MN8AUTyYyFFZ-TefiZMNWDvLnGjlUnv9BZvunba8CFn6HWFAAaFC9YUG2iwZYhASOQchogqzQ5bDxG_LYen_eqyJUJ89u0bsYWSlwfiFWNt37WbW6Fg=w1920-h1080-s-no-gm
AP1GczMXVautWWFRpVMsqVqSD2-Q_Wrw0euvtxvOoZj8SRhSztgqearGtLMLFX_cvci_UO3kOrzmD2jNjaebUwws2F9GuevTWh3BQpf1_bBUqpiuY5iDZtrJuOgFxqC7q1KqD2A3L1eKyupAX2l4S28irhXylw=w1920-h1080-s-no-gm
Blends in nicely with the red from the small Cupra logo
AP1GczM13v28fyJMjJsXt7mD0byFepgECgi41rqWBflzZRbFJjhuBjflozSSXQHqcf2FTxL9iPBwNs_aHa-Evkrs9uRjszyXudTcQhyhgoF7BzdOIPvZ5iKu9Kj4pGcA5W9JKvWJa7daDc4_-fTArMU8VA5_Yw=w1920-h1080-s-no-gm
Reactions: Mo_86
Michael_LeonV
54
20
Hiya,
Whilst fairly new to Cupra & the VAG family, still love the idea of tweaking the performance of my 2024 Mk4 Leon Cupra that has the 140kW DNNA EA888evo 4 engine.
I'v found though, that there is few and far between mods available for this model so far, so have only been able to upgrade the brakes to the Golf Mk7.5R PP units (340/310mm) units, and that's as far as I got.
There are a few posts from your upgrade that I'd like to get some additional info on re parts source, impact and general queries as follows please ;
Post #37 : https://www.seatcupra.net/forums/threads/nd-photo-nl-s-seat-leon-st-cupra-280.477591/post-5069686
The 'turbo muffler' confuses me a bit as it's probably a translation issue, but what does the replacement part do differently compared to the original ? Is there a performance benefit, or more of a 'it just runs better' impact ?
Do you have a link to the part you purchased ?
Post #39 : The "turbo elbow" seems to be a simple thing and just improves the inlet into the turbo, along with the silicone hose (Post #40). You mention the silicone intake hose, but removed it as it may 'collapse', is that because it was a poor quality part compared to the Do88 part ?
I've looked into similar parts from my engine/car combo, and seem to be SOL at the moment.
Post #41 : https://www.seatcupra.net/forums/threads/nd-photo-nl-s-seat-leon-st-cupra-280.477591/page-3
The "Diverter valve" - per the query re the turbo muffler, what is the prime benefit of doing this mod ?
Is there a good supplier/brand for these ?
and finally ...
Post #69 : https://www.seatcupra.net/forums/threads/nd-photo-nl-s-seat-leon-st-cupra-280.477591/post-5070454
The spacer block for the boost gauge tap, is there any difference between the evo3 & 4 engines ? And best supplier fopr one of these ?
Many thanks
Michael from Oz
nd-photo.nl
4,206
352
The Netherlands
youtube.com
Hi @Michael_LeonV , thanks for your reply!
I'm also pretty new to my generation Cupra, so things can be hit and miss. I adjusted my plans a little bit in the meantime. I want to see how far I can get with budget solutions. If the budget solutions are not satisfactory (can be either quality/fitment/performance/etc), then I will buy the tried & tested solutions.
I like to do things a bit differently here and there, instead of following the known paths.
Post #37 :https://www.seatcupra.net/forums/threads/nd-photo-nl-s-seat-leon-st-cupra-280.477591/post-5069686
I believe a (small) performance benefit as it flows a little better, and allows for a little bit more turbo sounds. The name muffler implies the last bit off course ;)
Check this website, this guy tested a lot: https://mygolfmk7.com/mk7-gti-turbo-muffler-delete/
I bought this set:
Yes, it boils down to cheap silicone hose. The known brands have better solutions and will have reinforced silicone hoses, which withstand pressure differences. Also the fitment is better for the known brands. In the meantime I went with another intake (with 3.5"hardpipe), which solved the intake hose issue for me. I will post this soon, so stay tuned :)
Post #41 :https://www.seatcupra.net/forums/threads/nd-photo-nl-s-seat-leon-st-cupra-280.477591/page-3
I can highly recommend the GFB T9381, which is an all-in-one replacement. GFB also has the one where you upgrade the existing DV. This makes the solution "bulkier" and didn't want to have a dependency on the stock DV. Prime benefit is reliability for me.
I don't think so, but I don't know the Gen4 that much. I bought this unit from Aliexpress, the only thing I changed is the screw being used:
nd-photo.nl
4,206
352
The Netherlands
youtube.com
Added a front upper strutbrace from TA Technix. The difference is definitely there, steering has become a bit sharper and it seems to tilt a little less in corners. Not bad for about 50 euro. Fitment is pretty good.
Our little doggo Nina doing a final inspection 🐶 & thanks to @tracktoy for some advice before I bought it
AP1GczPxAro7zYZZmPRQVcTpakki6GiL5Ow6OphkEWjiNUkSiyWu7m2ggtmighZPUOu2_pY_1PpwtnOn-hBgfGtsl67DX39UgMGRet7b4hYAeST8byqiqJlEvkS1dMbQxVkt4YGNaQabLswR657pUeMb9WPKKQ=w1920-h1080-s-no-gm
Build quality is good
AP1GczN96d5dijELiczquxke3q2Jue56NtLsC_v3xzvrbkT8DSVyklpttTFctyd_4mmXIZDsdtTul1A4sCTXrlLt1WoPgtwdaRcvnsb0WsvmuWQ7s4MuIqp6RS26PTbxDSvZuknlYe354lyeTkO4t-VoOml7QQ=w1920-h1080-s-no-gm
Work in progress
AP1GczN4FcZ_zU9rb85gg16XWgdJeP_MLTwOyMCNjX2a1LZLpwcKCejdy1DFoK-Iw3ApkfVyX0MeHXMk213CYff84pJZABV0hgqjcdiJOLk49wpmetW7_K1wW8DFE_uKfNayx7evWAUNOLk33lIpDkQh_Cohug=w1920-h1080-s-no-gm
I forgot to create a picture where its hidden under the trim, I will create that at a later time.
Reactions: Mo_86 and tracktoy
Michael_LeonV
54
20
Reactions: nd-photo.nl
nd-photo.nl
4,206
352
The Netherlands
youtube.com
@erminio Good too see you here :cheers:
Small modification, bought a red cover for the keyfob. Was pretty happy, but I bought another white one, which looks a little bit more stylish and fits the white of the Cupra better as well.
The red cover is put on the spare key. A cheap and easy way to pimp up the worn black keyfob
AP1GczPSNQd2mgS3ZouNp-HGcxf6fPUfXplmxcP4ksKqq6jxz-fU52bXLFLkV44dH2rSZNb-7zC0o14FqXama8NBhGGo3F_1EsTVnbeFZ3Rp7RCJYd-KcETj7zwigbVHZidLSMU_OHyabGmvtIVY2H5Ewm6eYQ=w1920-h1080-s-no-gm
AP1GczO6IG3mw9KBFSnz04tlif0NFtesmUoHlsXbqMJ93cnJTE0wJXFIyrqrYHOR6c9O6GbTyhs2kEbIUOQLTS39_4N9iEYhhs5iaIlJPEjz8UQ9lPafGfccZQvN3OOHViMz_WcK3Gm2a6f5uo8xGi2ePaUVHQ=w1920-h1080-s-no-gm
Reactions: WozzaB
