But if they then show profeshnialism, by using a torque wrench to see if they are tight enough?I'd be in favour of the death penalty for anyone using impact guns to tighten wheel nuts.
Or else they just have to have their own nuts tightened with an impact gun.I'd be in favour of the death penalty for anyone using impact guns to tighten wheel nuts.
How are your fingers feeling? Raw, I'll bet?Replaced the rear window wiper motor assembly - all because the rear jet was squished and not working
Worst bit was getting the plastic trim back on around the rear window.
Aww that’s a pain of a job.Replaced the rear window wiper motor assembly - all because the rear jet was squished and not working
Those clips suck. A couple of them go in 90° from all the other ones, so if you get replacements from eBay, you might have to saw a notch in them so they slide into the slots, because of course you do...
Made sure I got both types
Same here , pulley kits are not bad priced got one for £15 they all looked exactly the same including the branded, was only looking for the spline nut, at least there is access unlike other carsI have a mk2 and I think it's the first car I've had with such a pulley
i notice your running 235 tyres is there a reason for this? what do people normal run i have 225 40sGot round to fitting rear brakes, no disc and pads, looks well lots of more little ish jobs but cars in garage so they will have to wait. Thanks @Thai-wronghorse for the information needed and for supplying the rear disc.
No reason bud, my tyres needed replacing and my bro had these about, they fit great obviously a little extra grip due to the width had them on for a good few yrs now, but 225 is normal size but no harm at all with 235 eitheri notice your running 235 tyres is there a reason for this? what do people normal run i have 225 40s
