bruceR
2,558
647
Monifieth, Dundee
Replaced the rear window wiper motor assembly - all because the rear jet was squished and not working
Worst bit was getting the plastic trim back on around the rear window.
Reactions: Nathan penney
iammooks
1,784
1,172
How are your fingers feeling? Raw, I'll bet?
Nathan penney
Active member
Jul 8, 2017
723
836
Liverpool
Aww that’s a pain of a job.
Those little crocodile looking clips?
I had nightmare with mine a few years ago.
Making me sweat thinking about it. :ROFLMAO:
iammooks
1,784
1,172
Those clips suck. A couple of them go in 90° from all the other ones, so if you get replacements from eBay, you might have to saw a notch in them so they slide into the slots, because of course you do...
bruceR
2,558
647
Monifieth, Dundee
Made sure I got both types
Nam-uk
1,177
349
lancashire.
I'm sure there's an issue with the alternator pulley the noise has been bugging me for a while even before the cambelt and aux belt recent change, it was checked as usual and it run free, but other day while engine cold i put some release fluid down the back of the pulley just to test and the sound went away so oiled it after that, i even removed tension to check the pulley it seems fine.. looked at the spec and for a Ina pulley for 25 quid not worth risk they say they last 60-80k, might take it to garage or look at the tools needed, I've got the torx but there not long enough
andylong
494
Isn't there a sort of one way clutch and bearings in the pulley? To allow the alternator to run on when the engine revs reduce?
Nam-uk
1,177
349
lancashire.
yea its a clutch pulley and can can cause all sorts of issues like limp mode as it throws the electric system out and make a right mess if seizes if not sorted , its all new to me also since looking into it as i thought it was just a pulley lol
Nam-uk
1,177
349
lancashire.
I have a mk2 and I think it's the first car I've had with such a pulley
Same here , pulley kits are not bad priced got one for £15 they all looked exactly the same including the branded, was only looking for the spline nut, at least there is access unlike other cars
Dazzalcr
302
284
Lancashire
Got round to fitting rear brakes, no disc and pads, looks well lots of more little ish jobs but cars in garage so they will have to wait. Thanks @Thai-wronghorse for the information needed and for supplying the rear disc.
Reactions: Thai-wronghorse
Dazzalcr
302
284
Lancashire
i notice your running 235 tyres is there a reason for this? what do people normal run i have 225 40s
No reason bud, my tyres needed replacing and my bro had these about, they fit great obviously a little extra grip due to the width had them on for a good few yrs now, but 225 is normal size but no harm at all with 235 either
Nam-uk
1,177
349
lancashire.
Operation pulley
Ina pulley £24.50 same as the one removing, silly price at stealers it’s still a INA but in a vw box,
Altinantor kit £15.50 (same size spines as the door lock bolts) handy kit can be used for other jobs.
Nam-uk
1,177
349
lancashire.
Left one is the old pulley, defiantly been updated somewhere down the line
