Going to build a race 1m
Manic172
Dec 4, 2018
1,349
1,401
Hemel hempstead
www.seatcupra.net
Right am sitting at the services. The seat rails are in and extra gussets put in on the door bars.
I am going to have to buy a lorry or bigger trailer....
And always put your hash brown in the breakfast roll
Manic172
Dec 4, 2018
1,349
1,401
Hemel hempstead
www.seatcupra.net
Had another after noon down the work shop. I have been there on and off but not done much more just fettling and sorting stuff. But today was a bit of progress.
Starting off by stripping door locks so they can't lock.
So I removed the electric door locking system. And also the child lock system too.
. So in the end all I had was just the locking system. Also I am not having any internal opening pul as I don't need it . They won't be opened from the inside
Manic172
Dec 4, 2018
1,349
1,401
Hemel hempstead
www.seatcupra.net
Then on to building the rear doors.
Cleaned the door rubber and the window surround rubber. Then slid in the new polycarbonate window and fitted the window rubbers.
Then screwd the internal carbon fibre panel to the door
I have ordered some m4 nuts and bolts to secure the window in position. Also am writing a shopping list to send to Thai lol
Connor H
1,023
503
Essex
Then screwd the internal carbon fibre panel to the door View attachment 29018
only just noticed the toledo arches all blended and painted, looks absolutely proper mate
Reactions: Manic172
VT86
Leon 1.8 "CupraR" 4x4
Mar 22, 2012
329
75
Helsinki, Finland
Sorry I haven't yet read whole thread (yet) but are those rear fender extensions (and door) from BTCC Toledo? And have you more info on those in this thread?
Reactions: Manic172
Manic172
Dec 4, 2018
1,349
1,401
Hemel hempstead
www.seatcupra.net
There is some where in the thread how I cut and blended them in to the leon shape. Unlike the leon darkside had from northandsouth they just cut then end off lol
Reactions: VT86
Manic172
Dec 4, 2018
1,349
1,401
Hemel hempstead
www.seatcupra.net
Managed to get a few hours down with the old girl.
So playing with the pedal box and mounting it. I have now come to the idea of making a faulse floor about 50mm higher so the master cylinders on the back don't hit the bulk head..
I made a rough card template
Then transfered to 1.5 mm mild steel the cut it out with a grinder.
Then a few more adjustments it sort of fits
But now I am on ebay looking a buying a metal folder as I need to do a 45° bend on the front then make it fit to the floor. . Then position the pedal box.. Mark and drill holes then weld fixing to the back to bolt to. Then punch and sump some homes to lighten Then strengthen the panel.. I will put up pics when that is done. But I got a call out to had to pack up and go to a break down( I am currently on dafaid. That's a 24 hour call out for daf trucks in my area that break down or get faults etc.) Oh the joys.
Reactions: VT86 and MoToJoJo
Manic172
Dec 4, 2018
1,349
1,401
Hemel hempstead
www.seatcupra.net
Right. Been on the the phone to prorace engineering. After some time of talking of pros and cons or different ideas. I think we have come to the conclusion...... we are going for a garrett turbo.. not a g25 tho.. we are going g30-770 . Also with the stroker being a 2.0 and then ported and full race spec head this should be quite a set up..
MoToJoJo
823
653
Northants
Starting off by stripping door locks so they can't lock. View attachment 29013 View attachment 29017
So I removed the electric door locking system. And also the child lock system too. View attachment 29015 . So in the end all I had was just the locking system. Also I am not having any internal opening pul as I don't need it . They won't be opened from the inside View attachment 29016
Gonna have to have a go at this if for no other reason than not having to replace door locks 🤣
MoToJoJo
823
653
Northants
Jayzus! That’s a hell of an engine setup, any ballpark idea for power?
Reactions: iammooks
Manic172
Dec 4, 2018
1,349
1,401
Hemel hempstead
www.seatcupra.net
It's supertec valves and twin spring set up. Ported and matched ports to the manifolds. I have got the billing crank pull with pin kit. So bolt in to position ( arp crank pulls bolt) then drill and pin the pully to the crank. This will then help to stop shearing the woodruff key out .
Prorace do a twin pulley set up modification and then with race pec billit catcams. I thing it should have plenty of go in it. 82.5mm stroker pistons and I.e rods . Knife edged and balanced tfsi crank. To give the stroke. Should end up being pretty pokey lol
Manic172
Dec 4, 2018
1,349
1,401
Hemel hempstead
www.seatcupra.net
Boring few hours so grabbed the engines and stripped 1 and started to strip the other one. 1 is an AUQ and the other is AUG.
Now to give the block a clean and get it sent off for machining. Going to have 83mm pistons
Got to find some where that does hot washing or even a gental acid bath. Help to clear all oil and water gallery's (ignor the corsa..... its a scrap car I am using a a skip lol.. )
Reactions: Yellow fr
