My "Overtaking Right Prevention" still doesn't work. I have ticket open with support and sent them logs couple of times. I tried it yesterday around 13.00 last time and still no success. But it's not SFD related.
Is it split between generation 2 and generation 1 I wonder or did they mess up the systems after they launched SFD. I think most peoplr are on generation 1 with most early success on the Formentor or did generation 2 work fine at the same time that Agnes did her's. It's said generation 1 screens are better.Nothing worked for me either SFD or not can’t do nothing with my fancy OBDELEVEN gen 2 and pro plan.
Spoke many times with the support and shared many log files but nothing from them
Probably temporary issues. It has happened in the past.And unfortunately for IOS users like there is no other option
Any update ? when i get my steering fixed i need to do the overtaking right prevention also.My "Overtaking Right Prevention" still doesn't work. I have ticket open with support and sent them logs couple of times. I tried it yesterday around 13.00 last time and still no success. But it's not SFD related.
ok thanks ,one change i made will not undo it fails everytime ,i wanted it totally std for when it goes in next weekend to diagnose the steering fault.I sent them new logs couple of days ago and haven't heard anything back, just chased it.
That was a rogue micro payment app that Ninja had so what changes it did are not known or put another way what the long strings looked like are not known. For you, you can't action the changes again. It's been known in the past that Obdeleven has corrupted the cars programming which is the long string in each control unit. The back up shows that. Whilst you might have the history file if the software has taken to corrupting the long string, you aren't seeing the rest of it. That's why you are told to back up.Not sure if there's need to check long coding against another car, since there's history and you can see long coding changes. I changed Overtaking right prevention to Disabled in August and then changed it back in November, so have history for both actions. Now. I can't disable it again. But if @ninja_geezer has problem with reversing his change, it might have something to do with app problem, not our cars.
That's good, one to add to the list. Moral somewhere on those micropayment apps... I got 500 points now since I dont use them and given one point a day I power the app up .Control Unit 09
Adaptation
Daytime Running Light
Tagfahrlicht Dauerfahrlicht aktiviert zusaetzlich Standlicht:
New value: ON
Old value: OFF
This is what i used.
