Interesting. My first dyno run showed a peak torque of 309ft-lb, then Bill toned it down to 294.My car Maxed out on fuel pump first.
Did upgrade. Another Dyno and then the injectors were maxed and so added 550 injectors
Then another tweak and another run.
Car has more to give but stopped at 283brake and very near 300lbs so Bill stopped fiddling.
Time has come to push on abit more so rods are now on the cards.
Will see where they get me to with a mani fitted too.
Then when bored of that power it’ll have to be an 064 conversion.
Badger5 Custom Map + TIP,
@Sparkie - you'd better get your wallet forged too - the hold the large amounts of cash you're gonna need for your next mods.
I've definitely heard of people doing them from below, God knows how you'd compress the rings properly though plus clearance around the crankshaft would be stupidly tight.Shame you cant do rods without taking the head off ...or can you
I cant see how its possible tbh.I've definitely heard of people doing them from below, God knows how you'd compress the rings properly though plus clearance around the crankshaft would be stupidly tight.
I'll be in Brighton on sunday. If i see a random bloke giving me a thumbs up, I'll assume its you
What are you trying to say?
