What did you and your MK2 do today?
Brimfull
1,385
418
Wrexham
Applied a layer of chemical guys butter wax.
Also give up trying to install a copy of v16 maps and instead reverted back to installing v8 maps.
At least since I upgraded the firmware I now get 7 digit postcode search on my rns510.
Brimfull
1,385
418
Wrexham
Maintenance wash using auto finesse avalanche snowfoam.
Then another layer of wax applied
ZiggyEP3
406
72
UK
Some new tires for the front and prepping for the looming MOT time.
Need to check on the airbox as the garage that corrected the cross threaded fuel pump connector managed to break the airbox mounting on the right so the right hand side is loose but the left is attached OK.
Brimfull
1,385
418
Wrexham
Removed the diverter valve in anticipation that the new one arrives tomorrow. Discovered that the one fitted is the revision D plastic diaphragm type.
Not a bad job to undertake, just not much room to work in.
ZiggyEP3
406
72
UK
Yours stayed in one piece but mine fell apart when i took it out lol
Brimfull
1,385
418
Wrexham
It held together well. What revision do you have? I ordered a rev g so interested to see if they preform any different.
Not sure how long this rev d had been on the car but I am convinced I could hear a hiss under acceleration
ZiggyEP3
406
72
UK
I have a Rev G in now and had a D in before that had been on the car at least from 2013 until i changed it this year.
Legojon
I only wanted a remap
5,311
2,741
Did you notice any difference when you changed to the G??
I did when I changed mine. But that was going from factory original D at 7ish years old to brand new G. So might just be cause it was new.
Brimfull
1,385
418
Wrexham
Will be interesting to see if I notice any difference. I am convinced I can hear a hissing sound when under heavy acceleration, boost seems to come in a big dose at about 2500-3000rpm and then disappears very quickly.
Brimfull
1,385
418
Wrexham
The rev g diverter valve arrived this morning thanks to Awesome Gti
Well all I can say is that there is certainly a big difference from the rev d that was fitted.
The power delivery is a lot more linear and feels much less aggressive as the boost comes in smoother and stays for alot longer as opposed to coming in one big dolop and then disappearing just as quickly.
I can also now hear the engine more at high revs as the engine note was drowned out by a constant hissing sound.
I even managed to leave my £150 cycle light lodged in some suspension parts and after some very spirited driving was relieved to find it still in place when I got home
Legojon
5,311
2,741
Phew. Glad it wasn't all just in my head. Glad you got your light back as well. I've started using my intake heatshield as a tool tray. The number of rattles that panic me only to find a couple of spanners I've left on it. RIP the rubber washer I left on it last week and is now somewhere in the engine bay.
Reactions: Brimfull
