What did you and your MK2 do today?
Brimfull
1,385
418
Wrexham
Does it then also give a error code?
Verstuurd vanaf mijn SM-G930F met Tapatalk
Yes it can do if its particularly bad, mine didn't and many others don't have codes. It's only when you change it you realise that the old one was faulty.
For the cost of the part and the simplicity of changing it, if you have no records of when it was last changed it makes since to just change it.
Sent from my SM-G960F using Tapatalk
Reactions: PaulusB
Brimfull
1,385
418
Wrexham
Changed the pedals for genuine golf r32 pedals
Before
After
ZiggyEP3
406
72
UK
Before
After
Those are the pedals in my R so I assume they borrowed the parts from the VW line? I have a metal R logo footrest on the left not sure if that's stock or not. I can recommend one as it completes the set just nicely.
Reactions: Yellow fr
Brimfull
1,385
418
Wrexham
Standard mk5 r32 and golf gti pedals. I am slowly adding as many VW golf parts to the interior as I can, as the quality of the seat interior is the one aspect of the car I cant quite get used to.
My last three cars were Mazda, saab and Mercedes so going to the seat interior feels a little like a downgrade.
Reactions: SpiderWelsh
PaulusB
172
38
Changed my DV lot more boost now :) the old one was a G Serie also. This new one is a pierburg part nr 7.01830.13.0 same number as the G revision in the system of the seller, but still looks different don't no why. Before the new one u can here it dumping more air. I cannot see why the old is gone bad the seals are oke. Is the spring maybe wornout ??
New
Old
Brimfull
1,385
418
Wrexham
New
Old
The new one you have Installed is rev d, they last longer than rev g you have removed but the rev g performs better when its working
PaulusB
172
38
Drive likes nuts now. In the article in mygti its the other way around in the design with the colors old the black one new. I called the part shop the say the same I don't understand anymore :)
Brimfull
1,385
418
Wrexham
Started at 08:30 with an application of poor boys black hole, followed by a layer of chemical guys jet seal and topped with a layer of chemical guys butter wax.
Give the engine bay abit of a spruce up also.
First time I have used black hole and must say I am very impressed!!!! It did a great job of covering up some minor imperfections on the body work.
Photo of the engine bay now it's been dressed
Brimfull
1,385
418
Wrexham
Fitted a battery cover to do away with the cheap looking fabric cover and removed the oil filter neck as I no longer run the engine cover.
PaulusB
172
38
Is the fillerneck still in one piece?
Brimfull
1,385
418
Wrexham
Yes, apply a little pressure and you hear the glue pop and off it comes. I plugged the hole with a cloth mine you in case it did break
Legojon
I only wanted a remap
5,313
2,745
Which method did you choose and how easy did it come off? Mine really annoys me, but I've also read of some mishaps whilst removing it.
Brimfull
1,385
418
Wrexham
Warmed the engine up and applied a load of pressure to it and tapped it with a hammer a few times. Was about to give up and then I heard a pop and off it came.
Reactions: Legojon
PaulusB
172
38
Would u willing the sell me the neck as it not available to order ?
Brimfull
1,385
418
Wrexham
Said alot of swear words and shouted very loud at the bloody thing......
Front passenger side caliper stuck on whilst on the way home from work.
My head is slowly being turned away from the vag brand and turning towards a fn2 type r
ZiggyEP3
406
72
UK
I really liked my EP3 hence my username on here registered before I got the Cupra-R. EP3 is better than the FN2 as the EP3 has independant rear suspension the FN2 doesn't and is heavier. Dont lose faith with VAG though.
Reactions: Brimfull
