Ok thanks.
I am not sure i am going to do it however as it could invalidate my insurance and also as you say fail MOT.
I think this is everything from all the above,
Option ONE (Inner and Outer Lights together)
(1) Select Control Unit 09 Central Electrics.
(2) Select Adaptions (Code
(3) Select Leuchte23SL (Left Outside Rear Light)
(4) Change Lichtfunktion E 23 to Blinken links Hellphase
(5) Change Lichtfunktion F 23 to nicht aktiv
(6) Change Dimmwert EF 23 to 0
(7) Change Dimming Direction EF 23 to minimize
(8) Change Lichtfunktion G 23 to Blinken links Dunkelphase
(9) Change Lichtfunktion H 23 to nicht aktiv
(10) Change Dimmwert GH 23 to 127
(11) Change Dimming Direction GH 23,maximize
(12) Tick the Green tick box and save the changes
(13) Select Leuchte26NSL LA72 (Left Inside Rear Light)
(14) Change Lichtfunktion E 26 to Blinken links Hellphase
(15) Change Lichtfunktion F 26 to nicht aktiv
(16) Change Dimmwert EF 26 to 0
(17) Change Dimming Direction EF 26 to minimize
(18) Change Lichtfunktion G 26 to Blinken links Dunkelphase
(19) Change Lichtfunktion H 26 to nicht aktiv
(20) Change Dimmwert GH 26 to 127
(21) Change Dimming Direction GH 26 to maximize
(22) Tick the Green tick box and save the changes and backup to list of adaptions
Read more:
http://forum.obdeleven.com/thread/2071/rear-blinkers-coding-video#ixzz5MZen1jhJ
(33) Leuchte27NSL RC6 (Right Inside Rear Light.)
(34) Change Lichtfunktion E 27,Blinken rechts Hellphase
(35) Change Lichtfunktion F 27,nicht aktiv
(36) Change Dimmwert EF 27, 0%
(37) Change Dimming Direction EF 27,minimize
(38) Change Lichtfunktion G 27,Blinken rechts Dunkelphase
(39) Change Lichtfunktion H 27,nicht aktiv
(40) Change Dimmwert GH 27, 127%
(41) Change Dimming Direction GH 27,maximize
(42) Tick the Green tick box and save the changes
Read more:
http://forum.obdeleven.com/thread/2071/rear-blinkers-coding-video#ixzz5MZfWhsM8
The answer is yes, you code the first option (remember i coded this with the Rear DRL's on all the time) and add the following changes
On Leuchte18BLK HLA60, change Lichtfunktion A 18 from Blinken links Hellphase to nict aktive - turns off the indicator
On Leuchte19BLK HRC31, change Lichtfunktion A 19 from Blinken rechts Hellphase to nict aktive - turns off the indicators
